5 Channel Amp
Old Jan 4, 2001 | 09:05 AM
HotMax28's Avatar
what 5 channel amps does everyone recommend and i have a question about them. I know you can run it as a 4 channel for the door speakers and then there is an extra channel to run subs. Is this channel for use with one sub or two and is it bridgeable?
Old Jan 4, 2001 | 05:05 PM
amax935's Avatar
there are several good choices.
I can't remember the model # but one particular DEI appealed to me as good quality+ good bfb. What price range?
By definition you can not bridge a single channel. Yeah you can run two subs but it all depends on impedances and wiring configuration.
Old Jan 4, 2001 | 05:56 PM
Micah95GLE's Avatar
The sub channel on 5-channel amps is monoblock and they are all 2-ohm stable, so purchase subbage accordingly.
Old Jan 4, 2001 | 07:30 PM
HotMax28's Avatar
My price range? Hmm i'm looking to find a good quality amp and a hopeful discount price like wholesale or something. I guess like 250-300.
Old Jan 4, 2001 | 08:02 PM
amax935's Avatar
not much in that range
closest i see is hifonics zeus z700 for about 320. hifonics makes good amps, but zeus ia the low end.
maybe go 4 channel, run fronts on 1-2, bridge 3-4 for sub(s)
Old Jan 4, 2001 | 08:23 PM
jsmiam
Crutchfield has two models in their "specials" section, a Clarion and an Infinity.... http://crutchfield.com/S-74xYBcbKggG/specialscar.html
If I didn't already have an amp, I personally would be quite tempted by the deal they have on the Infinity amp....
Old Jan 5, 2001 | 06:36 AM
PrinzII's Avatar
OG and counting...
Try this for size
Many a/d/s amps handle the requests you are looking for. You can configure their amps to be 6 Channel, 5 Channel, etc. They can also handle a 2 ohm load very efficiently.
What I would do is look at one of the lower power plate series.
Old Jan 5, 2001 | 08:11 AM
HotMax28's Avatar
I don't know if this is a stupid question or not, but what is an a/d/s amp?
Old Jan 5, 2001 | 11:20 AM
PrinzII's Avatar
OG and counting...
a/d/s is a brand of audio equipment. A lot of competition vehicles use their amps (BTW, Precision Power is a subdivision of a/d/s), crossovers, and speakers. The thing about a/d/s is that they are among the cleanest sounding amps on the market outside of a McIntosh, Soundstream Reference Series, Alpine V12, Phoenix Gold, or Xtant.
Old Jan 5, 2001 | 11:44 AM
krell
Beware....
I'd be wary of 5 channel amps as some compromises have probably been made in the design in order to handle both full range and low range (subs) loads.
I purchased an Alpine MRV-F357 5 channel in order to power my rear speakers and a sub. The unit clipped quite a bit, in addition to some other problems. I bridged the 4 channel section, so it was running 80W X 2, 100W X 1 @ 4ohms RMS. This didn't cut it. I've been happy with Alpine otherwise.
I ended up buying two MRV-T707's. One runs the rears (70Wx2) and the other is bridged into the sub (240Wx1 into a 10" JL Audio W3). These amps also have Alpine's Bass EQ circuitry, crossovers, low freq filters, etc.....
It will be difficult to find a good solution in that price range. The 4-channel bridge solution that was mentioned would work (front/sub), and a lot of people these days are bridging their headunits to power the rear fill. I'm not fond of this idea.....
If you can save for another amp I'd buy a 4 channel and power the front/rear speakers with it. Later, score a decent sub oriented amp for the lows. This is how I started out. Ended up bridging the 4 channel for the fronts, and then buying the 707's.
-Andy
Old Jan 6, 2001 | 02:49 AM
Micah95GLE's Avatar
Re: Beware....
The better 5-channel amps have separate electronics for the high-frequency and low-frequency channels, merely sharing the chassis. The 5th channel is a separate monoblock unit, so there isn't a compromise. I haven't experienced any clipping with mine.
Old Jan 6, 2001 | 07:48 PM
krell
Re: Re: Beware....
Originally posted by Micah95GLE
The better 5-channel amps have separate electronics for the high-frequency and low-frequency channels, merely sharing the chassis. The 5th channel is a separate monoblock unit, so there isn't a compromise. I haven't experienced any clipping with mine. [/I]
Seperate power supplies as well? It's possible I got a defective unit. I run at least 4 gauge power cable to the amps, and haven't had any other problems with Alpine amps.
Old Jan 7, 2001 | 08:28 AM
Micah95GLE's Avatar
Hmm... I don't know what the problem is. That's unusual for Alpine stuff.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
minsbang
Sep 5, 2015 05:36 AM
