Bondo on wood?
Old Jan 22, 2003 | 09:36 AM
1MAX2NV's Avatar
Bondo on wood?
Is it possible to get that smooth glossy finish on a piece of flat wood with just primer and paint?
Or would I need to put a layer of bondo and lots sanding to get that smooth glossy finish?
Old Jan 22, 2003 | 10:54 AM
Maxima Dan's Avatar
I'm no carpenter, but I thought there were special wood fillers that you can lay down before you paint. I think you need something or else you would be priming and sanding for years.
Old Jan 22, 2003 | 02:28 PM
jmax
You can get a glossy finnish on wood. Think of a baby grand piano. Just lots of sanding and a high quality paint. Probably a few layers of clear coat would not hurt either. You would have to take the same steps if you were trying to get a glossy finnish on fiberglass.
Old Jan 23, 2003 | 08:26 AM
1MAX2NV's Avatar
I think those grand piano use some sort of polyurethane coating on top of woodstain. I guess I could sand it really good. Paint it and then follow it up with polyurethane coating. I might just take the easy way out and just use vinyl.
Old Jan 23, 2003 | 08:54 AM
jmax
For a thick clear coat you can try this:
http://fiberlay.com/
1046001 - SYSTEM THREE MIRRORCOAT EPOXY 1.5 PINT KIT $24.00
Old Jan 23, 2003 | 01:38 PM
Redmax's Avatar
Redlinemax Owner
Your last few Sanding couts will hav eto go up to 5000 to 10000 grit Sand paper for that smooth as a babys but finish
2kmaximel
Nov 29, 2015 01:51 AM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
2kmaximel
Sep 10, 2015 08:13 AM
