AMP Setup
Old Feb 4, 2003 | 08:26 PM
Frosty's Avatar
I am purchasing a Kicker 600.4 Multi Channel Amp. Can I run my front Speakers and Sub off the AMP and run my rear speakers off of my Headunit? Its a Kenwood Excelon 859.
Old Feb 4, 2003 | 08:49 PM
bahmax's Avatar
Shouldn't be any problem. It is a pretty common setup. Bridge two of the channels for the sub and then run the other two channels to your front speakers.
Old Feb 4, 2003 | 08:51 PM
Frosty's Avatar
Another thing, Should I get a 2ohm or 4ohm Kicker Solobaric 12 to go with this Kicker 600.4 amp http://www.kicker.com/ShowPage.cfm?f...html&menu=AMPS
Old Feb 4, 2003 | 09:48 PM
jmax
Get a single 4 ohm or dual 2 ohm sub. So that you can use the amp at it's most efficient and useful power level for the sub channel.
Old Feb 5, 2003 | 06:22 AM
Pearl96Max's Avatar
I tend to get a bit irritable
very common to do this, also being that your rear speakers main purpose is just for fill it should sound pretty good as well.
--Don
Old Feb 5, 2003 | 11:03 AM
Frosty's Avatar
--Don
Should I go with the 4ohm DVC Solobaric or the 2ohm DVC?
Old Feb 5, 2003 | 12:14 PM
Pearl96Max's Avatar
Use the dual 2Ohm this way you can run the amp 4Ohm mono and that should deliver 300watts I believe. I have them in stock too !
--Don
Old Feb 5, 2003 | 02:36 PM
Frosty's Avatar
--Don
Whats that you have in stock?
Old Feb 6, 2003 | 08:19 AM
Pearl96Max's Avatar
The Kicker subs
Old Feb 6, 2003 | 11:32 AM
Frosty's Avatar
How much for a Kicker L7 12" 2ohm?
Old Feb 6, 2003 | 02:25 PM
Pearl96Max's Avatar
email me MyPearlTPI@aol.com
--Don
Apr 16, 2020 05:15 AM
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
