Power antenna always up when HU is on
Old Feb 6, 2003 | 07:12 AM
Jkuan's Avatar
I install a Pioneer DEH-P4100 from my old car into the max. The headunit doesn't have a wire for Auto Antenna only a remote power. So I connected the remote power to the power for the Antenna; now everytime I turn on the radio even to listen to a CD the antenna stays up. Can I do anything so that the antenna only goes up while I listen to the radio?
BTW I have a 99 SE without the Bose system..
Thanks,
John
Old Feb 6, 2003 | 08:24 AM
jmax
Re: Power antenna always up when HU is on
Thanks,
John
You could put an on/off switch or relay in line with the lead going to the power antenna.
Old Feb 6, 2003 | 03:09 PM
erty67's Avatar
Decal Specialist
Re: Re: Power antenna always up when HU is on
that's about all you can do
Old Feb 6, 2003 | 04:32 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Yup thats all
Old Feb 6, 2003 | 06:18 PM
Jkuan's Avatar
Thanks for the info. I guess a on/off switch it is.
Old Feb 7, 2003 | 10:56 AM
WaZ's Avatar
WaZ
I had the same head unit on my probe. What i did was that I took apart the headunit ,and using my multimeter, found a wire that turns on with the radio on. connected the antenna wire to that, works like a charm. took me about 5 minutes to find it though. it's there.. good luck..
Old Feb 7, 2003 | 11:28 AM
erty67's Avatar
Decal Specialist
...and void any warranty that may be on the head unit.
Old Feb 7, 2003 | 06:08 PM
Pearl96Max's Avatar
agreed !
Old Feb 8, 2003 | 08:13 AM
jmax
Ah, you squeamish installers. If you don't break it, how do you learn to fix it?
Old Feb 8, 2003 | 12:56 PM
Pearl96Max's Avatar
Ahhhh very good point, but with that theory do YOU want to be one of my customers James??
--Don
Old Feb 9, 2003 | 12:03 PM
Wisky97SE's Avatar
I have a Pioneer P8400MP, and mine does the same thing, but if you think about it; if you switch from your CD to the radio often, I rather just have the antenna up all the time, thats less wear on the power antenna. I say leave it the way it is . .. but if it's really bugging you, bring it to an install shop to install a remote switch.
Old Feb 9, 2003 | 01:34 PM
WaZ's Avatar
WaZ
How many times have you actually used the warranty on a hu? I have bought and used about 10+ hu's and have never used the warranty on it. I was just giving an option.
Jkuan.. sorry i couldn't email you back rightaway but you do have to take the cover off the hu, and the wire you need is right by the power supply. If you are not 100% sure about what you are doing, i recommend you just to install a switch. Good luck.
chisam14
Nov 6, 2018 08:56 PM
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
