Bose HU replacement
Old Feb 6, 2003 | 09:56 AM
johnnyrock's Avatar
Bose HU replacement
Hey all,
I've done multiple searches, and still am not sure if the Scosche FAI-3 adapter is necessary. I plan on just replacing my head unit. I already have the new H/U, the harness adapter and the dashkit. I also plan to keep the existing bose speakers and amps. Also will the amps work properly with a new H/U?
Thanks ahead for any advice.
John
Old Feb 11, 2003 | 06:51 AM
wildmaxi's Avatar
bose
have you put in your new h/u..did you use the fai-3..I got new h/u kept speakers from bose..used fai-3...not working no sound...any reason why..email me..need help
Old Feb 11, 2003 | 07:23 AM
sidewinder740's Avatar
Re: Bose HU replacement
Originally posted by johnnyrock
Hey all,
John
If you plan to replace your Bose head unit and use the Bose speakers/amps make sure you have this: http://www.crutchfield.com/S-YPG5Mvm...i=142CNN03&s=0 and also make sure you have an antenna adapter too!
Old Feb 11, 2003 | 07:27 AM
slavik'sMAX's Avatar
I am not sure if that's a good idea to keep original bose speakers...
As far as I understand Bose HU has a low output, and therefore there are amplifyers for each of the speakers, if the new HU has higher output, you might end up damaging your speakers.
As far as the harness, I think it's just time saving, I don't think it's required if your willing to match the wires "manualy"
Old Feb 11, 2003 | 10:10 AM
96SE NUH?'s Avatar
I just replaced my bose h/u with an alpine. The only thing that happens with the speakers is that you wont have that great of volume control. At Volume level 4 its already kinda loud, and at 5 its load enough to where it gets distorted. Thats the problem with not replacing the bose speakers.
Old Feb 11, 2003 | 04:46 PM
dwapenyi's Avatar
If you really really want to get the best out of replacing your Bose HU, get the PD-4 here;
www.linkmeup.com
It's kinda pricey ~$180 with harness. BUT, it is the ONLY Bose adapter that allows you to use the Line out RCAs from your new HU and plug them directly into the Bose AMPS/Speakers. You get the cleanest signal without double amplification and you keep the BOSE sound and get all the features of your new HU.
I used the PD-4 to replace my Bose HU wtih a Clarion MP3 unit
DW
Old Feb 11, 2003 | 06:05 PM
willis's Avatar
My heroine
hey all,
just a question. to avoid the distortion and loss of volume control with the factory amp on the speakers, can't you just cut the amp out of the loop.. I'm not sure how exactly the maxima's are set up, but on my old sho, there was a factory amp that caused problems with a new head unit. If you just wire around that, it solved the problems. isn't this possible with the maxima system??
wJ
if i'm completely wrong, don't shoot me, I haven't gotten my max yet (tomorrow) so I haven't had a chance to actually look..
Old Feb 11, 2003 | 06:19 PM
dwapenyi's Avatar
Yeah, you can do that, but then you'll lose the BOSE sound. All the BOSE sound is done by EQing/auto loudness etc in the HU and AMPS.
DW
Originally posted by willis
hey all,
wJ
Old Feb 11, 2003 | 06:46 PM
willis's Avatar
My heroine
Hi again,
after reading the faq (novel idea, I know).. i have just one more question. The part listed on crutchfeld above(http://www.crutchfield.com/cgi-bin/S...nfo&i=142CNN03), has anyone had experience with that and does it work. The second part listed in this thread is nice, but at 180 is way too much.. I just want a solution to keep the bose effects of the speakers, but be able to put in my sony blackface head unit. Thanks for any help
willis
Old Feb 12, 2003 | 04:57 AM
johnnyrock's Avatar
The part listed at crutchfield, is it the same as the scosche fai-3 listed at sound domain for half of the price. (www.sounddomain.com/sku/scofai3)
Old Feb 12, 2003 | 05:36 AM
willis's Avatar
My heroine
I dunno if it's exactly the same, but it appears close. I think you need to buy a harness for it though, so that might jack up the price a bit.. dunno if the crutchfeld one needs a harness or not
wJ
Old Feb 12, 2003 | 05:47 AM
johnnyrock's Avatar
wJ
The harness that you speak of, is it one that you can pick up at a best buy or pep boys. i picked one up at best buy for $15.99 and i believe that it was made by metra dash works.
Old Feb 14, 2003 | 11:15 AM
dwapenyi's Avatar
Check this out
http://www.installer.com/cars/nissan.html
DW
Old Sep 14, 2003 | 07:20 AM
litxus's Avatar
Hi, I'm trying to install new JVC HU and so far I got the antenna adapter all the harnesses and "dash kit". As far as I understand I also need something like Soche FAI-3 in order for my stock speakers to work with new HU. Is there a website where I can find the whole installation process of new HU for Max'es with pics? And also can anyone give me the complete list of things that I need to replace Bose HU with aftermarket HU. Thanks.
6spd4dsc
May 9, 2022 12:30 PM
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
melteye
May 16, 2016 12:02 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Maxinesdaddy
Aug 21, 2015 11:43 PM
