Diamond Audio 12D4 M6 Sub Question
Old Feb 11, 2003 | 06:56 AM
Ma><iManiac's Avatar
On the website, it says that it can take 800W RMS, but it gives no max wattage rating. Does anybody know if this sub could take a 1200Wx1 feed? I've got the JBL BP600.1 amp, and I'm thinking about trading it in for a BP1200.1. What do you guys think? Do you think it would sound significantly better, or just a little, or not at all?
Thanks,
Lloyd
Old Feb 12, 2003 | 12:34 PM
Anybody??
Old Feb 12, 2003 | 04:34 PM
Nathan's Avatar
Re: Diamond Audio 12D4 M6 Sub Question
Thanks,
Lloyd
I got a quick question. How much did you pay for that Diamond Audio sub and where did you buy it from?
Old Feb 12, 2003 | 07:05 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Yes I have hooked them up to DA 1200.1s and they take every bit of it. Check with NaMike, he has that setup i his car.
--Don
Old Feb 12, 2003 | 08:21 PM
jmax
I would say it depends greatly on the enclosure. You could waste 1200 watts on a single M6 with the wrong enclosure. Or you could use it more carefully to power a pair. The difference by ear between 600 and 1200 watts is truly not enough to cause shoulders to shrug. You can get the same difference by building a larg4er sealed box. Or for even greater amounts of bass, as you are obviously seeking, go ported.
Old Feb 12, 2003 | 08:54 PM
Here's the deal..I'm not really seeking more bass, per se... What I am seeking is firmer sounding bass. I got it when I went from my 300W IDQs to the 600W (bridged single) DA M6. I was thinking that doubling the amps would make the bass even more "firm" and less shaky. Does that make sense?
Old Feb 12, 2003 | 09:43 PM
jmax
Explain "less shaky". Are you saying hte system has the traditional boomy sound quality? If so it could be many things.
Old Feb 12, 2003 | 10:22 PM
My old subs did. The new Diamond is a lot firmer, but I was wondering if I went with an amp that could drive the sub closer to it's max, if it would sound even more "firm". What do you think? BTW, running in a single 12" sealed enclosure. I am going for SQ, NOT SPL.
Old Feb 12, 2003 | 10:36 PM
Pearl96Max's Avatar
Lloyd,
Also keep in mind to give the sub a "breaking in" period.
--Don
Old Feb 12, 2003 | 10:51 PM
jmax
What Don is saying is a possibility. I remember when I first hooked up a MacDaddy it took a good month to break in. Then it was a bit more efficient. A small box is a good way to keep from going beyond X-max. But it won't keep you from frying the voice coil with too much power. I would not try to exceed Diamonds recommendations by much.
And I still need a better description of your problem.
Old Feb 12, 2003 | 11:02 PM
Wow, I wasn't aware of a break-in period. Does that mean I shouldn't pound the sub hard yet? Or just that it will take a while before it sounds it's best?
As far as a better description of my problem..That's difficult to do as it's something you can only describe by actually hearing it. The bass is more solid with the new sub. The tones are clearer, and less raw rumble. Just a tighter overall sound. I just wonder if I could get even more of that with more amps. Apperantly 1200W should be no problem for that sub, according to Don. But, that is just more money for me to spend, that could really go to paying off some debt. I just want something to consider for later down the line I guess. I still have to shell out $170 for a viper alarm, and I want my windows tinted. If you still dont get what I'm sayin, don't worry about it. I need to let the sub break in anyway. Thanks for your help though.
Lloyd
Old Feb 13, 2003 | 07:27 AM
jmax
The bass being tighter probably has more to do with the enclosure / sub relationship than the exact power output of the amp. 100 dB is not abnormal for a single watt of power in car audio. You can do the formual's for doubling amp power and the relative increases in SPL. I think you have to have ten times the power to gain 3, 6, or 10 dB. I really don't remember the formuala. There is a very definite point where the sub will sound louder but will not measure as much louder. This is where distorion starts to play in. If it starts to "sound loud", it's most likely distortion. If you look at a speaker on a graph as you increase power output should increase in a linear manner. When the output compresses, that's because the sub has reached it's linear limit. More power will not be louder as the sub can move no more air than what it is at full excursion. The only way to move more air would be to go beyond the linear limit, or use a port. Well, there may be a few other ways to do it but don't worry about that now.
Old Feb 13, 2003 | 07:43 AM
I don't want louder. I want tighter, more solid bass. I can't explain it.
Old Feb 13, 2003 | 07:55 AM
ObsidianIce69's Avatar
I think that what you're saying is basically you get a bass hit and instead of that quick forceful hit it sort or "warbles" and extends a bit right? If you're getting that it would probably be the enclosure, not the power you have. i'd take a look at that and not sweat the amp yet.
Old Feb 13, 2003 | 08:53 AM
jmax
People often think they can judge how loud a sub is with their ears. But our ears are horrible at distinguishing differences in fidelity in the low frequencies. I would say that it is somewhat the enclosure, and somewhat your impression of what good bass should be. Tight is in the mid-bass, not sub bass. If you want more tight bass raise your crossover frequency.
Old Feb 13, 2003 | 09:28 AM
I have it set at 125.
Fbana41
Aug 29, 2016 12:18 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
