Help! on Head unit swap
Old Feb 12, 2003 | 09:36 AM
JM95max's Avatar
The head unit in my 95 GXE (non-Bose, single DIN AM/FM/CASS) retired itself. I went on eBay to upgrade to a CD unit, & won a Bose Double DIN unit with single CD.
Installed unit last nite, and all parts work, but sounds like $#!^!!!
I need to know if I missed something? Or is the amp in the unit toast(under 30 day warranty from eBay seller)?
Or do I need improved speakers?
Sounds either over or under powered for he speakers.
Please advise!!
Thanks, Jim
95 GXEw/roof Stock as they come, 120K.
Old Feb 12, 2003 | 10:08 AM
MacAlert's Avatar
Re: Help! on Head unit swap
Please advise!!
Thanks, Jim
You have underpowered speakers. If I am correct, the 4th Gen Max Bose speakers have individual amps.(amps an each speaker) You might have to change the speakers.
Old Feb 12, 2003 | 10:27 AM
dwapenyi's Avatar
Re: Re: Help! on Head unit swap
Yup. It's an in-complete BOSE system. You'll need the amps for each Bose speaker and the BOSE speaker themselves. Ain't no half steppin'
DW
Old Feb 12, 2003 | 11:07 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Yes the above posts are correct, you will need the rest of the Bose system for it to work correctly. Although it still will only sound as good as Bose can after all the time and effort you will put into it.
--Don
Old Feb 12, 2003 | 11:12 AM
JM95max's Avatar
Bose Head unit
Thanks for the quick response!
Next ?, Do I have to get the Bose speakers&amps, or could I get aftermarket speakers from another mfr that would play from the Bose head??
BTW I just found this site & LOVE IT. Thanx to all
JIm
Old Feb 12, 2003 | 11:31 AM
MacAlert's Avatar
Re: Bose Head unit
This might be totally wrong. You can get different speakers but will need an amp to power those speakers because the BOSE radio is not supplying enough power.
Old Feb 14, 2003 | 09:52 AM
Dayle97SE's Avatar
the general concensus of the people here seems to be that it's not worth it to try and and add the bose system to a car that did not already come with it. You would have to spend alot more money to get the rest of the system - the speakers and amps - not to menion time and aggravation. You should have gotten the non-bose double din unit. It looks exactly like the one you got, except it doesn't say "bose" on the face.(it also has it's own internal amp, unlike the bose headunit) Maybe you can return it, or sell it and get the right one. I know alot of people on here don't like to bother with the oem stereo stuff, and prefer to get an aftermarket headunit. I myself prefer to keep the factory oem look on the dash, and I'm sure I am not alone. But, everyone has different needs, and tastes in audio. well good luck, if you need anymore help, most of the members on here have been through it all.
Old Feb 14, 2003 | 10:36 AM
dwapenyi's Avatar
Re: Re: Bose Head unit
Well, almost. The BOSE HU doesn't have and standard lineout RCAs or anything, and even if you were able to tap into the audio signal coming out of the HU, the frequency response would be non-standard. So you would have to make it standardized somehow.
DW
Old Feb 14, 2003 | 12:42 PM
JM95max's Avatar
Re: Re: Re: Bose Head unit
DW
Thanks TONS for the help guys . I can't return the unit, and am relisting it on eBay for what I have it it (the reserve is $121, plus shipping.) See link below.
I am very glad I found this site. If anyone from maxima.org wants it, I'll sell it for $100 plus shipping. Email me at maynardus@aol.com
The auction ends 2/19.
J
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2403640887
Old Feb 14, 2003 | 01:12 PM
Dayle97SE's Avatar
by the way, here are some links to some non-bose maxima double din units on ebay right now, in case you have not already seen them...
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6774
http://cgi.ebay.com/ws/eBayISAPI.dll...category=32815
Old Feb 14, 2003 | 01:33 PM
dwapenyi's Avatar
Did you see this site?
http://www.installer.com/cars/nissan.html
I just saw it in another thread. It gives you a few more options with the Bose HU.
DW
Old Feb 16, 2003 | 11:07 AM
eclypsecl's Avatar
is it possible to leave my bose HU in there, and attach an aftermarket INTO the bose HU..? SO that it plays into bose, and outputs into speakers.
Old Feb 16, 2003 | 01:29 PM
dwapenyi's Avatar
Nope. The BOSE HU is either the heart of your system, or it's not. No in-betweenies.
DW
Old Feb 16, 2003 | 03:11 PM
eclypsecl's Avatar
it's ok i bought a http://cgi.ebay.com/ws/eBayISAPI.dll...008324304&rd=1
Old Feb 25, 2003 | 03:36 PM
maksim80's Avatar
DW
Actually, I've setup original Bose (double din) and my AIWA CDC-MP32 in one car. I am able to switch which HU I want to hear by a toggle switch that controls relays. I do get a large amount of noise occaisionally from bumps(can't fix). Also, generator seems to add a nice sound effect on acceleration. Mine's an auto, when shifting from P to R to D, sound may dissapear from front or rear.
My relays have plastic covers. Does anyone think that it may help to get rid of interfence from generator or gears by putting an outside sheild on all of the relays and also grounding the shield?
thnx
James92SE
142
Jan 2, 2024 09:23 AM
Mar 12, 2020 12:06 AM
ivorton23
Sep 28, 2015 09:08 PM
Socalstillen
Sep 20, 2015 11:46 PM
MaxRPM6
Sep 11, 2015 06:56 PM
