Sub Hook-up
Old Jan 9, 2001 | 05:22 PM
cryptopsy23
I know this is possible
Lets say i got a 1 channel amp how do u hook up 2 subs to the one channel
the amp is 1200x1
I forget how to hook up the subs
Does this sound just as good as if i were to hook em up to 2 channels
or
Would i be better off lets say usin one sub that handles up to 1400 watts with just one amp?
i am not sure how 1 sub with that many watts is as good as 2 subs with lets say 800 watts combined
Old Jan 9, 2001 | 11:12 PM
GarthG's Avatar
I would assume that you could just run 2 sets of speaker wire from the one output of the amp; which in effect would be the same as wiring the subs in parallel. . . Only problem is you would have to make sure the amp can handle the new resistance of the 2 speakers wired like that. If they are both 8 Ohm speakers, then the resistance is equal to 4 Ohms, and if they are both 4 Ohm speakers, then the resistance is equal to 2 Ohms. The sound quality will be just as good as long as you aren't trying to do stereo sound with the subs, which I don't think anyone does.
Old Jan 10, 2001 | 09:58 PM
CustomMax
You can always have a box built for the two subs with a mono port. Meaning, that the speaker outlet (where you hook the wires comming from the amp to) would only have 2 ports, one for negative and one for positive. Both subwoofers could be wired to that one port.
TunerMaxima3000
52
Jun 9, 2021 10:25 PM
ohsheetadrian
Mar 26, 2011 12:20 PM
sicivic89
Jan 24, 2008 12:59 AM
MyownNismo
Nov 24, 2002 10:41 PM
Smoothb2002
Jun 21, 2002 08:58 PM
