power inverter
Old Feb 20, 2003 | 09:08 AM
sagamax's Avatar
Give me a Bud Light Holmes
power inverter
i am soon puttin my ps2 in my max and i want to know if i can use my 4 gauge amp wires to power my power inverter. would that be enough power. i have a red top optima powerin the whole car.
Old Feb 20, 2003 | 09:09 AM
sagamax's Avatar
btw i am plannin on puttin a 600 watt power inverter.
Old Mar 19, 2003 | 11:39 AM
areX's Avatar
I don't know if you ever got the answer to this, but what brand of Inverter are you using?
the 4 gauge should be fine if it's a good inverter. More juice never hurt.
Old Mar 19, 2003 | 11:45 AM
Kojiro_FtT's Avatar
What do you need 600 watts for? Are you plugging a large screen TV in with it?
Old Mar 19, 2003 | 11:54 AM
areX's Avatar
hahaha... a washing machine perhaps?
Actually, my company sells power inverters (one of the top 5 in the market) and we run anywhere from 75-5000watts. you can power quite a bit with 5000watts. lol
Old Mar 19, 2003 | 12:44 PM
psu max's Avatar
the inverter is capable of supplying 600 watts of power, but it will only give as much power is needed
if you havent bought your inverter yet, i believe target is selling a 750 watt inverter for 62.98 (its on clearance, so your target may/may not have one)
oh and as far as powering the ps2, it should be more than enough... in fact you could probably get away with 200-300 watt inverter
Old Mar 19, 2003 | 12:48 PM
96MAXIMAGXE's Avatar
i powered my ps2 with a 140watt power inverter. but it wasnt hardwired. i want to get a 300watt just to be safe, but i dont know how to hardwire it anyone have a write up or some pics? i`m not the best when it comes to wiring.
Old Mar 19, 2003 | 12:51 PM
areX's Avatar
the PS2 only takes 85Watts. even with a laptop (P4) a 200W will more than suffice. Beware, though, not all inverters are the same. Note that they will say 300watts, but it'll actually be 250W continuous and 300W for 30minutes. Here's a quick plug: WAGAN Tech inverters are always underrated at continuous wattage (24hrs). Check the GD if you're interested.
Old Mar 19, 2003 | 12:56 PM
areX's Avatar
you'll have to find an accessory wire and a ground to wire the thing. up to 300W, most cars don't need to be hardwired. I just tapped my cigarette lighter.
what kind of inverter are you using, btw? and is it filtered?
Old Mar 19, 2003 | 12:58 PM
i`m using a ge power inverter. will it be safe to tap into the cigarette lighter? and i dont know if its filtered or not? dont even know what that is.
Old Mar 19, 2003 | 01:00 PM
by the way if i tapped my cigarette lighter. should i fuse it power wire?
Old Mar 19, 2003 | 01:04 PM
areX's Avatar
filtering is internal to the inverter or as an optional accessory you get at radio shOck. do you sometimes get buzzing noises from the radio? if so, maybe you need to get a filter.
When you tap into the cigarette lighter, you'll need to put in an inline fuse for extra precaution. the inverter should be fused already for any overloads.
Old Mar 19, 2003 | 05:49 PM
sagamax's Avatar
hey i have a cobra 300 watt continious and 600 watt max power inverter. i just wanted to make sure i had enough power to keep everything running smoothly.
I just bought a distrubution block that goes from 4 gauge to 8 gauge wire and i have fuses in the block. i just want to know where do i get a switch so that i still use my amp wire but it only get power in acc because i dont want it to get continious power. i dont want it to drain my battery. somebody please help!!!!!
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
