Need help with blinking ABS light
Old Feb 23, 2003 | 08:42 AM
bazsu's Avatar
Hi,
I need some help guys. I have a 1995 Maxima with dual air bags. I was working on my dash yesterday, and I disconnected the driver's air bag (as suggested in the manual) to avoid an accidental inflation. Then I made the mistake or reconnecting the battery and turning on the ignition to test the radio before I reconnected the air bag's connector in the steering wheel. Now the air bag check light on the instrument panel blinks constantly after it comes on initally whenever I have the ignition on.
Does anybody have any clue to what can be the problem?
I assume there is a fault code in the ABS computer. Does anybody know how that can be deleted or the computer reset?
Thanks for any input,
Bazsu
Old Feb 23, 2003 | 06:13 PM
dwapenyi's Avatar
If I rememebr correctly, you reset your airbag computer like this:
a. Open the drivers door.
b. Put the key in the ignition and turn it to the run position.
c. hit the button for the drivers door at least 7 times within 10 seconds (so your dome light goes on and off 10 times.)
Hopefully, that should fix it.
DW
Old Feb 23, 2003 | 07:25 PM
bazsu's Avatar
DW
THANKS A LOT. It worked. I tried everything (disconnecting the battery, turning the ignition on and off 15 times, connecting both battery cables to the positive terminal of the battery) but nothing worked so far. I was about to go to the dealer to have the computer reset.
Thanks again,
Bazsu
PS; Where can one learn about these tricks???
Old Feb 23, 2003 | 07:30 PM
bazsu's Avatar
DW
Thanks again,
Bazsu
Old Feb 23, 2003 | 07:53 PM
dwapenyi's Avatar
Nissan FSM
DW
Originally posted by bazsu
. . . PS; Where can one learn about these tricks???
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
Maxie40
Sep 14, 2015 11:28 AM
dcardello
Sep 3, 2015 11:44 PM
maximusrising
Sep 2, 2015 09:55 AM
