Bose HU is removed, Kenwood HU is installed
Old May 23, 2005 | 04:16 PM
  #81
rustyram02's Avatar
I knew I shouldnt have gotten the bose! This is just turning into a headace. Went to bestbuy and asked them about the Metra PN# 70-7551 and they said that they do not carry it. I'm just going to buy the one online and try that out. With all this trouble I should just replace the whole system but I dont want to go through the trouble of replacing the sub too. someone shoot me!!!!
Old May 23, 2005 | 04:42 PM
  #82
Taxvictim's Avatar
Mine sounds great. They used the Metra 70-7550, which is what they had. There was a little electrical interference from the engine and even some clicks and pops when the CD would change tracks, so I took it back in and they fixed that.
Old May 29, 2005 | 05:20 PM
  #83
hb07's Avatar
ok I just read through the entire thread and am still a little confused. I have a 96 Maxima with the Bose system and want a different head unit. I understand if I need to buy the
ROEM-NIS2 kit to keep the Bose speakers.
My question is will I lose audio quality or not????
does it bypass the bose amp?
or put your new headunit signal into one the bose amp and speakers can handle giving you the same sound quality??
Old May 29, 2005 | 08:24 PM
  #84
AdamK's Avatar
I don't think it bypasses it...all I can tell you is it sounds much better than stock with a new HU and adapter
Old Jun 6, 2005 | 04:44 PM
  #85
capblye's Avatar
Howdy all,
Great thread with a lot of good info for a newbie like me ...
Ive got a 92 Max SE, with all the stock Bose. I really just want to put in a CD Player, but not a cd changer.
Can anyone point me to a decent HU, and a link for the adapter i need?
Id like to keep cost down, so im not lookin to spend a bundle on the HU.
Thanks much in advance
Old Aug 15, 2005 | 11:21 AM
  #86
sraey8's Avatar
The PAC home page directed me to a local dealer that stocked their products, and when I called this dealer he said that they don't stock them because 'generally' they don't have to use the NIS2 kit to install a aftermarket HU and still utilize the stock bose stuff. He says that he would run a non-bose adapter and it would be fine; might play 'louder' at lower levels, but would be fine unless loud isn't what I was looking for.
My concern is that since the bose amp was designed for a signal input (2-4 volts) instead of radio output used in the form of input (20-40 watts), that doing it this way would fry the factory bose amp.
What do you guys think??
Old Aug 16, 2005 | 02:02 PM
  #87
kpr10is's Avatar
Wow. This has to be the longest running non-stickied thread ever.
Read the stickies before you post please. Specifically for you, my post in the Car Audio FAQ Sticky.
Thanks.
Old Aug 16, 2005 | 05:07 PM
  #88
AdamK's Avatar
I did the reinstall myself and the audio shop said just use the cheapo nissan harness which worked fine, i read on here though that i might burn out the amp and hu if i put the volume up or after a while so i decided to be safe and get the 46.00 thingy
Old Nov 4, 2005 | 11:25 PM
  #89
kauaiwyatt's Avatar
my antenna doesn't go up either
i have the schosche oea4 adaptor & a pioneer DEH3700 H/U. i also used the ant. adaptor crutchfield gave me.
i'm not sure how to connect the antenna power wire from the PAC to the headunit? Do I connect it to the blue/white wire? The antenna does not go up at all, but i still get good reception.
Any advice?
Old Jan 22, 2006 | 04:35 PM
  #90
MaxRain's Avatar
can i install the pioneer DEH 6700 using PAC ROEM-NIS2 with the bose amp and speakers and then add an amp for my subs from the head unit?
Old Feb 10, 2006 | 01:57 PM
  #91
MarineMax's Avatar
Here is a fix to a problem I ran into installing a pioneer hu in my 02.
After wiring up the ROEM-NIS2 into the aftermarket harness, I could not get any sound coming out of my speakers. The hu turned on, but nothing came out. After reviewing the fact that the bose system uses factory amp's, it donned on me that you need to have the blue remote wire connected in order to "turn on" the factory amp. Most cars do not use this blue remote wire in my experiance installing aftermarket hu's so I did not think it was used here.
Just my 0.02 in case someone else had the same problem.
Old Feb 10, 2006 | 02:01 PM
  #92
Pearl96Max's Avatar
I tend to get a bit irritable
This thread just keeps on living huh?
marinemax, good info, but its been covered numerous times already. Especially in the FAQs.
Old Mar 2, 2006 | 12:58 PM
  #93
flashhsalf's Avatar
im gona bump this topic once more..
will this Double Din DVD player fit in my 2000 5th gen without any modifications?
http://www.circuitcity.com/ccd/produ...c=1&oid=133511
they say it won't fit, but i've seen people with double din's in their cars??
im pretty comfused.
Old Mar 2, 2006 | 01:06 PM
  #94
djfrestyl's Avatar
Suspension Yoda
It will fit.
Old Mar 2, 2006 | 01:33 PM
  #95
flashhsalf's Avatar
It will fit.
thanks.
i have also see a gap on the top that is visible in all setups i've seen, is there any way to get rid of that, a kit or something for the double dins?
does anyone know the dimensions of the hole where our stereos fit?
Old Mar 2, 2006 | 01:42 PM
  #96
djfrestyl's Avatar
Suspension Yoda
I covered it up with a slice of ABS plastic.
http://www.eden.rutgers.edu/~nbalani...g/CIMG1030.JPG
Old Mar 2, 2006 | 02:14 PM
  #97
flashhsalf's Avatar
thanks, i'll probably will have to do that as well. Did you have any troubles installing the unit? or was it just plug and play with the Scosche adapter?
thats a nice unit...how much did you get it for and what model?
Old Mar 2, 2006 | 02:15 PM
  #98
djfrestyl's Avatar
Suspension Yoda
No problems with the unit. Once you know where all the wires go, that's about the end of it.
Price is somewhere around 1500. Eclipse AVN-5435
Old Mar 2, 2006 | 02:21 PM
  #99
flashhsalf's Avatar
thanks
i just hope it won't stick out too far.
Old Mar 2, 2006 | 02:22 PM
  #100
djfrestyl's Avatar
Suspension Yoda
Then mount it further back, keeping in mind the face is motorized. Mine can go a little bit further back without it hindering the movement.
Old Mar 2, 2006 | 02:59 PM
  #101
flashhsalf's Avatar
i'll keep that in mind, I was assuming that wasn't enough space in the hole so it might stick out, but i guess there is plenty.
btw do you know of any good sites that sell wide varieties of these dvd players?
Old Mar 2, 2006 | 03:13 PM
  #102
kpr10is's Avatar
Expect about 10-15 trips back to circuit city to have them fix the problems youll have with that jensen.
Old Mar 2, 2006 | 03:24 PM
  #103
djfrestyl's Avatar
Suspension Yoda
There are only a few manufacturers of double din screen'd head units.
Eclipse, Pioneer, Kenwood, Jensen, maybe one or two more.
Old Mar 2, 2006 | 03:25 PM
  #104
djfrestyl's Avatar
Suspension Yoda
BTW that previous list is in preferential order.
From "real good" to "wouldn't buy it as a paperweight"
Old Mar 4, 2006 | 12:20 AM
  #105
BlackMazi's Avatar
Do you need to replace the stock tweeters as well if I only wanted after market speakers and HU?
Old Mar 4, 2006 | 07:07 AM
  #106
djfrestyl's Avatar
Suspension Yoda
Typically if you replace with coaxials you remove the tweeters and don't use them anymore. If you replace with components the tweeter will be replaced.
Old Jul 2, 2006 | 10:10 AM
  #107
tvmaster's Avatar
nissan/infiniti pac oem-nis2 popping audio
I just read your post, albeit a little old. I just installed an Alpine 9857 with the pac roem-nis2, while retaining the stock Bose amp / speakers. everything sounds great except for a turn-on pop. I why would this appear with an aftermarket head unit and not the stock Bose head unit?
Is there a built in delay in the Bose head unit? Or maybe a grounding issue that I have overlooked?
Old Jul 2, 2006 | 10:12 AM
  #108
djfrestyl's Avatar
Suspension Yoda
Wow this got bumped again...
Old Jul 2, 2006 | 11:22 AM
  #109
1996blackmax's Avatar
Maxima.org where old threads never die .
and ofcourse I am not helping either with my post
Old Jul 2, 2006 | 12:14 PM
  #110
tvmaster's Avatar
the reason for the long bump...
this site won't let me post until I have responded to 15 other posts.
So even though I would like to post an entirely new question on this topic for people to help me with, I have to find an old post that is similar and hope someone can assist from there, for the time being.
thanks
Old Jul 2, 2006 | 12:17 PM
  #111
Understood, still kind of funny though .
Old Jul 5, 2006 | 07:58 PM
  #112
popapakj's Avatar
hey
hi, anothe newbie here. just got a 99 non bose system. i got everything i needed from this site (FAQs and all) but just had one final question.
i'm installing a singel din, and since theres gonna be a gap, i want to put a pocket in. just wnated to know what was the best. i'm planning on using the stock brackets and all. i think Camn talked about it, but the site won't let me PM him.
"ps... my max.. and every nissan Ive ever had.. uses a universal single-din pocket. No trim kits or anything required... in fact, they usually wont fit!"
what pocket did u use?
this
SCOSCHE - NN2155B - Replacement Pocket Kit For 1985 & up Nissan
http://www.audiooutfitter.com/store/NN2155B.html
or
metra 98-7499?
http://www.installer.com/item/displa...php?it=98-7499
or somethign else? just need to know what pocket works so i cna order and be on my way to installing it. thanks all for ur patience and help..
Old Jul 5, 2006 | 08:05 PM
  #113
djfrestyl's Avatar
Suspension Yoda
this
or
metra 98-7499?
I've got a spare 4th gen pocket (with flip up door) if you want it.
Old Jul 5, 2006 | 08:07 PM
  #114
popapakj's Avatar
nice.. i assume it would fit in the spot were the tape deck used to be (the bottom half of the double din?
how much?... pic?
Old Jul 13, 2006 | 01:09 PM
  #115
YoMax's Avatar
Hi, I've just signed up for this forum and I found lot of information here.
I'd like to replace broken Bose HU in my Maxima '96 with Alpine CDA-9833. From this thread, I understand that I'll need Metra 70-7551 harness and antenna adapter. Do I need to get anything else?
So I plug RCA connectors in Metra 70-7551 to preamp outputs in Alpine HU. But how do I connect other wires, like power, etc?
Also somethere else I read that this HU needs "direct fuse to battery". What does it mean? Should I worry about this?
Thx
Old Jul 13, 2006 | 01:10 PM
  #116
djfrestyl's Avatar
Suspension Yoda
Read some stickies. What year is your car?
Old Jul 13, 2006 | 01:22 PM
  #117
burnurass's Avatar
11 MORE!
Old Jul 14, 2006 | 09:51 PM
  #118
YoMax's Avatar
It's Maxima 1996 (4th generation) with Bose system.
Is there a chart that shows how to connect wires
from Metra 70-7551 to wires from HU?
I have not got 70-7551 yet, but I've seen its picture that shows a bunch of wires coming from it (apart from RCA plugs).
Old Jul 15, 2006 | 05:24 PM
  #119
djfrestyl's Avatar
Suspension Yoda
Just connect the wires that are the same color.
red-red
yellow-yellow
blue (w/o stripe)-blue (w/o stripe)
orange-orange
You're going to have to find a ground.
And then your green/white/purple/grey are taken care of.
Old Jul 17, 2006 | 08:14 AM
  #120
YoMax's Avatar
djfrestyl, thanks a lot.
