Cheapest XM Solution
Old Mar 8, 2003 | 04:20 PM
WaarrEagle's Avatar
I have decided to buy XM radio and am looking for the cheapest way to get it. I want to buy the AUX adapter for my Bose so what is the best way with rebates and all to get this. Which antenna is best if I plan on putting it on my rear deck? Also, is it worth it to buy two adapters (total of around $100) to get a direct signal to my head unit instead of FM modulation?
Old Mar 9, 2003 | 07:41 AM
mzmtg's Avatar
Minister of Silly Walks
You can get awesome deal on Sirius satellite radio these days.
Sirius is better than XM anyway.
ALL Sirius music streams are commercial free.
They use variable bitrate streaming (the streams that need more bandwidth get it, the one that need less are cut down) this leads to better overall sound quality.
Their satellite system is more advanced. They have three satellites that are set up to orbit so that at least 2 of them are directly over North America at all times. XM only has 2 satellites that are always positioned directly over the equator.
To put that in perspective, Sirius only needs half as many ground based repeaters as XM.
Check out www.sirius.com and the forums at www.clubxm.com for more info.
Old Mar 9, 2003 | 08:25 AM
WaarrEagle's Avatar
Yeah, a friend of mine has XM and I just assumed that was better but I read a huge thread on clubxm last night about xm vs. sirius and I am starting to lean the other way. I found if I buy the Pioneer receiver from Crutchfield it has a $100 instant rebate plus a $100 mail in rebate through XM so it would be free. The only problem is that it is on backorder. Where is the best place to get Sirius equipment?
Old Mar 9, 2003 | 05:38 PM
mzmtg's Avatar
Most vendors are offering the Kenwood Sirius tuner ($160) for free when you get the sirius antenna for $70. They may not mention it, but ask for it.
Check out page 4 of my homepage for my setup using the Kenwood FM modulator for Sirius.
Old Mar 9, 2003 | 08:11 PM
WaarrEagle's Avatar
Does that deal include the display as well as the decoder? How deep is that display? I want to mount it elsewhere on my dash since I still have the stock headunit in.
Old Mar 9, 2003 | 08:30 PM
mzmtg's Avatar
The main components of the system are the antenna, the tuner and the controller. The controller is either a Sirius-ready headunit or an FM modulator. If you are keeping the stock headunit, you need the FM modulator. I think they are about $60.
The FM modulator controller is about 3/4 of an inch thick.
Old Mar 9, 2003 | 08:42 PM
mzmtg's Avatar
http://forums.maxima.org/showthread.php?threadid=195441
Free gear...
Old Mar 9, 2003 | 08:44 PM
WaarrEagle's Avatar
Thanks for the link! Do you think it would be worth it to buy the AUX adapter and do all of that instead of the FM modulator?
Old Mar 10, 2003 | 04:21 AM
mzmtg's Avatar
Not really...
Maxboy23
55
May 1, 2025 06:09 PM
homewrecker
Sep 23, 2015 03:41 AM
jchronis2552
Sep 21, 2015 05:52 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
dvcamp
Sep 18, 2015 10:17 AM
