where do tweeters go?
Old Mar 13, 2003 | 03:26 PM
PaulCT's Avatar
im looking at infinity spekers for my 96 max and most come with seprate tweeters... where do these go in my car?
Old Mar 14, 2003 | 07:04 AM
Kojiro_FtT's Avatar
Re: where do tweeters go?
Either in the a-pillar or near top of the door panel. You want the tweater up closer to ear level, but it's also recommmended that the tweater be not more than 2 feet away from the woofer (otherwise you it will seam as two different sound sources).
Old Mar 14, 2003 | 07:34 AM
hrygeek's Avatar
We put the tweeters in the front pillars and the rear pillars. Go to page 2 and you can see where we cut the Kappa tweeters in.
http://maxima.cardomain.com/id/2k2kevpearlse
Old Mar 15, 2003 | 11:18 AM
nubiannupe's Avatar
OG Maxima.org Member
I put the tweets from my Boston ProSeries 6.5's on that little triangle atop the door panel (just behind where the sideview mirrors mount).
Old Mar 15, 2003 | 12:11 PM
max'n out's Avatar
THe answer is where ever it works and gives you the sound you want.
Common places are...The kickpanel, the a piller, the mirro cup, coax mounted over the mid, and some cut a hole in certain spots in teh door and put um there.
Old Mar 19, 2003 | 09:37 AM
sagamax's Avatar
Give me a Bud Light Holmes
i custom drilled my tweeters in the door panels right before my door handle it is a clean job. but i recommend either drill in ur door panel if u know wat ur doin or get a professional to do it for u.
95naSTA
Sep 21, 2015 06:50 PM
MikesChevelle
Aug 9, 2015 11:50 AM
1MAX2NV
Jun 19, 2001 12:27 PM
hlh0501
Jan 29, 2001 04:17 AM
ericdwong
Jan 26, 2001 05:51 AM
