ohms 2k3 Bose
Old Mar 17, 2003 | 10:28 AM
vqman
ohms 2k3 Bose
ok, so the tweeters are 4 ohm...
what are the rest of the speakers...all of them?
what can i replace them with...
I want to keep the stock head unit...looks more adult.
thanks
-vq
Old Mar 17, 2003 | 12:59 PM
VMosser323's Avatar
Re: ohms 2k3 Bose
thanks
-vq
Good question....bump.
Old Mar 17, 2003 | 05:44 PM
vqman
another bump
thanks for the bump....bump
-vq
Old Mar 18, 2003 | 08:37 AM
ssmithmax03's Avatar
The Speakers ohm out as follows:
Front Tweeters: 4 ohm (Actual 3.7)
Front door (6 1/2): 1.7 ohm
Back Doors (6 1/2): 2.2 Ohms
These are what mine are in my 2003. I have started replacing most all of the factory equipment. I will have pictures posted soon of the (2) JL 8ww3v2's in a sealed enclosure mounted up in my back deck soon.
Shane
Old Mar 19, 2003 | 06:02 AM
vqman
Shane
so I have to replace EVERYTHING?
does anyone make a 2.2 ohm speaker? or a 1.7 ohm speaker? Those are both pretty close to 2 ohms...
how many ohms in a regular house speaker...maybe I could buy a 2 ohm HI-end house speaker, and drop it in? I really don't want to get rid of the factory look...
are regular house speakers 8 ohm? or 2 ohm? or what?
-vq
Old Mar 19, 2003 | 06:10 AM
vqman
Shane
what about the sub in the 2k3 rear deck?
-vq
Old Mar 19, 2003 | 06:47 AM
Most home speakers are 8 ohm drivers. The subwoofer is a 1 Ohm driver with it's own built in amp on the bottom of the speaker. What I did was replace the factory amp with a JL Audio 500/5 (5-Channel amplifier. This amp will run a 1.5 ohm load and still stay stable. I am switching out all the drivers, but I have been running this amp on all the factory highs without a problem. No one that I know of makes a 2 ohm midrange or tweeter that I know of. I kept the factory deck also for now.
Shane
Old Mar 19, 2003 | 09:04 AM
vqman
ok, front I'm going to try and understand everything
FLT-front left tweeter 3.7 ohms
FRT-front right tweeter 3.7 ohms
FLM-front left mid 1.7 ohms
FRM-front right mid 1.7 ohms
RLM-rear left mid 2.2 ohms
RRM-rear right mid 2.2 ohms
SUB-sub - 1 ohm
now how many amps are there?
how do they get there signal? low level, speaker level...
and if there are more than one amp, which amp drives what speakers...
what is each amps output (watts rms) what is each amps input
give me every detail you know...
thanks for the help.
-vq
Old Mar 21, 2003 | 06:43 AM
vqman
bump
Old Mar 21, 2003 | 06:41 PM
Kojiro_FtT's Avatar
Do yourself a favor and just get one of those Bose converters to hook the factory Bose HU to an aftermarket amp and rip out everything but the HU. Still looks "adult" (a.k.a. theft deterent) and it'll be easier than trying to match ohms (btw, home speakers are usually either 4 or 8 ohms). You could even get a free air sub for the rear deck. Heck, the easiest would be to get one of those JL infinite baffle subs and the JL 500/5 (100w x 2, 25w x 2, 250w x 1) mount the amp on the back of the fold down seats and the sub in the stock location and there you go, completely stock looking.
(didn't mean to plug JL, just an example setup)
Old Mar 24, 2003 | 12:32 PM
vqman
where can I buy a "Bose converter"? what do they cost?
thanks
-vq
Old Mar 25, 2003 | 06:29 AM
studman's Avatar
Check the audio forum FAQ. I wrote about this a bunch.
And BTW... the stock HU is a good portion of the problem with the Bose setup. It's not worthy of carrying the Bose name.
But on the flip side, it does look nice.
Old Mar 29, 2003 | 08:05 AM
vqman
nice write ups...
but I couldn't find out where to purchase one.
-vq
Old Mar 30, 2003 | 08:22 AM
shortchaz's Avatar
nice write ups...
-vq
If your just going to add in an amp put in line out converters. This is what I have in my car. From what I understand on the BOSE in the 2k3 is that you need to take the signal before the amp. If you take the signal after the amp you get all the weird bose eq cr@p. There are plenty of g35 guys that have done this and shouldn't really be any different on your car other than wire colors I would think.
jmlee44
Oct 2, 2022 02:13 PM
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
