trunk rattling questions
Old Mar 25, 2003 | 09:03 AM
s0ber's Avatar
Im about to buy a 4th gen maxima and I was wondering if you audio guys have alot of trunk rattling?? and if you do how much dynamat do you think i'd need to quiet it up? I hate rattling I wont put in my stuff into I can get it fixed anyways, thanks!
BTW im running:
Kove Audio KC610 Components front/rear.
MA Audio M486I 800w Amplifier for the mids n highs
MA Audio MA2582HX 1300w@1ohm for the subs
3 Hollywood Edge 10"'s 600w rms 1000w max running @1ohm
JVC KD-SH99 Mp3 player/cd whatever...
Old Mar 27, 2003 | 02:21 AM
lunchbox's Avatar
My trunk rattles like crazy. The back deck does too. I have yet to get any sound deadening, but i woudn't buy dynamat. Get some brown bread or rammat, its cheaper and as good if not better. I don't know how much it will take. Just get a lot, theres nothing wrong with having extra.
Kevin.
Old Mar 27, 2003 | 09:10 AM
crazyravr's Avatar
You have to unerstand that dynamat and such is not the solution to all the rattling problems. It helps but it will not stop everything. When you determine what exactly is rattling then you can tackle the problem.
Old Mar 27, 2003 | 06:52 PM
DR0832's Avatar
well
I got a question reguarding this as well. What do you do about the tire well in a 4th gen. do you just cover the hole thing with sound deadening material including the tire well and the entire rest of the trunk? I know that the door panels definitely need it because those rattle with the stock system. I can imagine how bad that rattle would be with a real sub pumping out 600+ watts.
Old Mar 27, 2003 | 10:43 PM
lunchbox's Avatar
the whole trunk floor, lid and sides. Don't go over the spare tire, but yes, into the well. i have some random rattles that dynamat can't help, so its time to get mcgyver on it. Also, dynamat is not a cure all...it won't get rid of all rattles.
Kevin
Old Mar 27, 2003 | 10:58 PM
s0ber's Avatar
whatever helps is good enuf for me... i cant stand rattles, i had some random rattles in my 626 that i couldn't find, felt like ripping the car apart :|
Old Mar 28, 2003 | 09:07 AM
DR0832's Avatar
question
what about do you put sound deading on the actual enclosure under the carpet or what ever its covered with? What did you guys do to level out the surface of the trunk? The surface of my trunk is very warped. Is putting a piecec of MDF custom cut a bad idea?
Old Mar 29, 2003 | 12:09 PM
lunchbox's Avatar
All the max trunk are uneven, at least as far as i know. I just put a piece of wood in there to level it out.
Kevin
lrb6805
Sep 17, 2015 04:49 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
rbaker100
Sep 6, 2015 02:46 PM
