Sound dampening question
Old Apr 3, 2003 | 08:03 PM
DR0832's Avatar
This is a question for people who have dampened there trunk and cut MDF in the to give the trunk a flat surface instead of using the warped masonite. Do you put sound dampening on the bottom of the MDF wood (not the box) that you cut the same shape as your rug? Also do you secure the MDF wood surface (not the box) to the car with something or is it just sitting on top of the sound dampening material? If so what dp you use to secure it?
Old Apr 4, 2003 | 03:19 PM
capvent's Avatar
I put the sound deadining in the tire well.
I used MDF and put foam on the bottom as to not mess up the deadening material. I put it under the MDF with adhesive spray glue.
Little to no vibrations from here.
Hope this helps.
JR
Old Apr 4, 2003 | 06:20 PM
DR0832's Avatar
question
what type of foam did you use, and where can I get it? Home depot or local place...?
Old Apr 4, 2003 | 06:35 PM
nadir_s's Avatar
vicodin ... gift of life
when you guys say MDF... do you mean the sound dampening stuff they use for roofing?? If so... what brand did you get and where? I am considering doing this for the tirewells and stuff but i have heard that it will smell like tar when the temprature is hot?
any input on that? Thanks.
o yea 1 more thing, when you guys put it in the tirewell... did you put it on top (interior cabin) or underneath the tirewell side (outside).
Old Apr 5, 2003 | 08:56 AM
DR0832's Avatar
MDF = a type of compressed wood people use for building sub enclosures.
Peel and seal - a cheap alternative material to dynamat for sound dampening. You can buy it at Loews I believe.
Old Apr 5, 2003 | 09:34 AM
nadir_s's Avatar
Originally posted by DR0832
MDF = a type of compressed wood people use for building subs.
thanks
Old Apr 5, 2003 | 12:36 PM
capvent's Avatar
Used "egg crate foam" for beds. You can get it for cheap, aroung $15, at a k-mart or target. Get the twin size and you should be fine.
When the instal is done, you will not even see it under there.
Good luck.
Old Apr 5, 2003 | 05:36 PM
DR0832's Avatar
well
that could be a problem. My box just barely fits height wise. If I put egg crate foam I don't think it will be able to fit. damn
Old Apr 5, 2003 | 09:24 PM
Nore474's Avatar
where can i get his peal and seal stuff?
Old Apr 7, 2003 | 06:02 AM
capvent's Avatar
The box will fit. It is foam after all. Worth a try.
Peel & Seal can be purchased at a local Lowe's Home Improvement.
Good luck guys.
JR
Old Apr 7, 2003 | 01:50 PM
Nore474's Avatar
do you guys have pictures of installing these sound deadening materials on the trunk lid?
thats where i get the most rattles,
I was told to put foam in the trunk lid behind the M A X I M A emblems does this make a mess?
and what kind of expansion foam?
Old Apr 8, 2003 | 10:03 AM
hrygeek's Avatar
Peel and seal is a cheap alternative. The only drawback is that it stinks like no other. When it heats up it stinks even more. MDF= Medium Density Fiberboard. It's compressed a lot more than cheap particle board and you shouldn't need to put any dampening on top or bottom. The expansion foam we used for the trunk lid was Great Stuff and can be found at Lowe's or Home Depot. Automotive expansion foam is best but can be pricey. As long as you dont put any expansion foam behind the lock you should be fine.
maxima.cardomain.com/id/2k2kevpearlse
Old Apr 8, 2003 | 10:50 AM
Nore474's Avatar
so you just fill the whole thing up with expansion foam? except for the lock part?
my box is made out of MDF i just gotta stop the trunk from rattling
Old Apr 8, 2003 | 10:59 AM
hrygeek's Avatar
I'll try to post pics of what I'm talking about
Old Apr 8, 2003 | 01:11 PM
releasedtruth's Avatar
rilla dope
Man, this thread just keeps going. There are hundreds of posts on deadening. It's really not tough, try some things out, tons of options work just fine
Old Apr 8, 2003 | 04:58 PM
DR0832's Avatar
well
well unfortunately sound dampening is pretty permanent, and its not that cheap. If I go experiment and it doesn't work out well, then I am ****ed. Thats why I asked questions. You don't have to answer or even read the thread if you don't want, and neither does anyone else, but I think that this is what the org is here for: To learn and help each other out, no matter if it takes 1 reply or 1 hundred. i mean I am sure I am not the only one out there thats looking for this info and since the search its hard to find other threads, unless you spend hours upon hours reading, which I for one don't feel like doing.
Old May 2, 2003 | 01:19 PM
Playero's Avatar
Sanduguero
you got a point!
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
RWCreative
Sep 21, 2015 11:01 AM
TheMafia
Sep 4, 2015 08:26 AM
sdotcarter
Sep 2, 2015 09:53 PM
