Amp Install......... Help Please............
Old Apr 7, 2003 | 09:40 PM
my2ndmax's Avatar
Hi I want to install my amp myself. I have done my headunit and front and rear speakers so all that is left is my sub and amp. Does anyone know of a site that has pictures of an amp install in a 3rd gen. This is my first time doing an amp install and I just want to see how someone else ran their wires and everything. Any and all help will be greatly appreciated. Thank You.
Old Apr 8, 2003 | 09:53 AM
hrygeek's Avatar
If you give me more details, I will help as much as I can. Or email me.
Old Apr 8, 2003 | 10:11 AM
my2ndmax's Avatar
I want to install the amp but I dont know where to run the ground or power wires. I mean everyone says run from the trunk to the battery through a gromet in one of the wheel wells and stuff like that but actually seeing it is easier to follow than reading how to do it. I know if I see someone elses install I could do it myself. I was hoping that someone had taken pictures of their install so that I could see it being done.
Old Apr 8, 2003 | 10:37 AM
hrygeek's Avatar
What kind of time frame are you looking at? Email me at hrygeek@***.net and I will take some pics.
Old Apr 8, 2003 | 10:40 AM
my2ndmax's Avatar
Hey thanks a lot I really appreciate your help. I mean I dont really have a time frame I will do it as soon as you can take the pics. When ever you get a chance you can email them to pnnyhrdwy1@aol.com and once again I really appreciate it.
Old Apr 8, 2003 | 11:40 AM
Cumalittle
run power wire from battery to trunk....
-trace all the wires going thru fender wall...on driver side..take of the black plastic piece...u will see a group of wires goin thru a gromet...i mean it don't get any simpler...poke a hole an run wire thru...
-run under carpet...
-not necessary to remove rear seat but i'd rather do that cuz more room to work w/...
run ground...
-should be less then 3 ft in length...as short as possible actually...
-find a good part of the frame...and use self tapping screw...or use existing bolts...make sure to scrap all the paint if there is any...
run remote...
-most deck has only one wire for amp remote and power antenna...usually blue or blue/white...if u have both then great cuz one is for power antenna and the other is amp remote...
-run along the same side as power wire...
run rca cords...
-run it the same way as power and remote but on the other side of the car...
-if ur rca cord has 16 gauge or wateva size wire in the middle...common mistake is that it's used for amp remote...i've even seen it advertise on one amp kit as so...but infact u should groud both end...
Old Apr 8, 2003 | 12:55 PM
hrygeek's Avatar
run ground...
run remote...
run rca cords...
Cumalittle, the whole install depends on what is being put in. If he's going to be running all new wiring for the spks in doors (components require wire for both mid and tweet depending on where crossover is mounted) then he might not have enough room to run 8 speaker wires, and 3 rca's in a channel that is 3/4". Every install is different. Using the grommet by the fender will work if not that many wires will be running down the channels. In our case, that was not possible with 8 (16ga stinger) speaker wires(x-overs in trunk), 3 rca's. We came in right below the vacuum booster and made our own grommet so we could run power down the middle (w/rem) and then had clear channels to run everything else down.
maxima.cardomain.com/id/2k2kevpearlse
Old Apr 8, 2003 | 01:12 PM
Cumalittle
huh??? only time i mention running wire thru gromet @ wheel well is for power...from my understanding it's just sub and amp that he wants to wire up...am i mistaken???
Old Apr 8, 2003 | 01:17 PM
Cumalittle
hehe...i ran my power wire just like u did...we even put the fuse at the same location...same color wire too...
Old Apr 8, 2003 | 01:18 PM
hrygeek's Avatar
He doesn't specify.
Old Apr 8, 2003 | 02:06 PM
Cumalittle
He doesn't specify.
my2ndmaxI have done my headunit and front and rear speakers so all that is left is my sub and amp. Does anyone know of a site that has pictures of an amp install in a 3rd gen.
so i'm assuming just amp and sub...plus even if the amp gonna push the 4 speakers...my instruction should still hold true...well atleast thas how i installed mine...
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
