Help Real Quick Question
Old Apr 23, 2003 | 11:42 PM
SupaMax's Avatar
Alright I just got a 2 channel 800w Kenwood amp and want to hook it up to my speakers. I have pioneer 6x9's in the back which hold about 260w each and 4" in the front that hold about 100w each. Will my amp work for the pairs. Just want to make sure before I go and get it installed tommorow.
Old Apr 24, 2003 | 06:18 AM
Dohcser's Avatar
Re: Help Real Quick Question
First you need to verify what OHM rating the amp is good for, usually 4 and 2 OHMS.
Since it is a 2 channel amp and you have four speakers you will need to run each pair of speakers off, of each channel.
The speakers are probably 4 ohms each, if the amp is good for 2 ohms then you will need to wire up the (2) 6x9's in Paralled and the (2) 4" in Parallel, then have the 6.9's go to one channel and the 4" go to another.
By the way when you run an amp in 2 ohms it will be hotter.
Also if you do this keep in mind that your amp only has one gain control. Your 6x9's can handle more power than your 4", in turn you are limited to turning up the gain (or volume of HU) to where the 4" sounds good!
Just get a 4 channel amp!
The Frye
Sep 2, 2021 11:03 AM
Mar 12, 2020 12:06 AM
dcam0326
Sep 18, 2015 04:52 PM
A32goldylocks
Sep 14, 2015 06:49 PM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
