4th Gen amp install link with pics?
Old May 19, 2003 | 01:34 PM
wilked's Avatar
Does anyone have a 4th Gen amp install procedure with pics?? Didn't see it in the FAQ's
Dan
Old May 20, 2003 | 04:54 AM
vabeachmax's Avatar
You run the wires, and plug them into the amp. What else do you need to know? It's not hard to do.
Old May 20, 2003 | 09:33 AM
wilked's Avatar
Sorry, first amp install. I wasn't sure where exactly to drill through the firewall, and should I run all wires together down the driver's side door?
Old May 20, 2003 | 10:10 AM
inj3n's Avatar
Lesson 1 - NEVER run the wires down the same side of the car
Old May 20, 2003 | 10:46 AM
vabeachmax's Avatar
Run the power wire and RCA's on opposite sides of the car. You will end up getting interference if you run them on the same side. You dont have to drill a hole either. There is one above the ECU I think. It's been so long since I ran my power wire I forgot exactly where it is. There is one up there though, I'll check and get back to you.
Old May 20, 2003 | 01:57 PM
quiksand's Avatar
Be specific, that statement is bland and confusing.
Seperate/run your power cables away from your other cables, i.e. RCA and Speaker Wires. Running them together will introduce noise into your system.
Finkle
Sep 27, 2015 09:53 PM
ef9
Aug 27, 2015 07:21 AM
mikekay
Aug 10, 2015 12:52 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
MikesChevelle
Aug 6, 2015 11:36 AM
