All 3rd Gen owners...
Old Jan 24, 2001 | 05:18 PM
Cincy94Max's Avatar
I'm making my mounting brackets for 6.75"s up front and I wanted to know who all has done this. I already have an idea and have traced the OEM plastic piece that mounts to the door. Then I was planning on using a few more layers of wood to get the correct depth for my speakers. I need a total of 1.5" of wood height and I don't forsee any problems with this. I'm thinking of using 1/4" or 3/4" plywood and good old Elmer's wood glue. Does anyone have any suggestions or comments about my ideas. I just want to make sure I'm not making a huge mistake anywhere and waste a bunch of wood. Thanks in advance for all your help.
Old Jan 25, 2001 | 01:03 PM
Cincy94Max's Avatar
please...
Can someone just tell me what thickness wood they used?
Old Jan 25, 2001 | 01:38 PM
«§»Craig B«§»'s Avatar
I just used 1/4 for my 4x6 up front
Old Jan 30, 2001 | 10:21 PM
Whitey's Avatar
Re: please...
Take it easy on yourself a bangin system doesn't allways mean the biggest speakers. Why do all that work when 4 inch speakers fit right in with some fiberglass and Resin. Thats what I did and It bangs. I put pioneer 4s and sealed it with fiberglass and it sounds incredible with the stock bose cabanet.
Yee Whiteness
Old Jan 31, 2001 | 05:48 PM
Cincy94Max's Avatar
been there, done that...
I already had 4x6"s up front and there was and still is zero midbass. My cheap *** 6.5"s in the back have decent midbass, so I'm going with 6.75"s all around. If I don't like the sound, the store I bought them from has a 30-day return policy. Oh, and as an update, I used 3/4" wood for the mounts and it was a pain in the ***. I had to chisel out a 3/8" channel along the wood in order for the door to fit correctly over it. Hopefully my speakers will come in by Friday so I can get everything hooked up!
Old Feb 1, 2001 | 04:56 PM
amax935's Avatar
I missed your first post
definately hold out for 6.5s. i used 1/4 plywood for the bottom plate, and 3/4 mdf for the ring. 1" will work out with *most speakers*. I set the mdf at an angle with two screws, used fiberglass and bondo to reinforce and fill ( and remove screws. with the screws I was able to image a little better and get a real exact fit. the bondo and glass was a real pia.
it would be a good idea to seal the bottom plate to the door with some silicone sealant
Old Feb 23, 2001 | 10:53 PM
CanuckAMP's Avatar
1/2" mounting plate with a 1/2" mounting ring for the speaker should also work well. What are the depth of your replacement speakers? I've fit speakers up to 3" depth in my Max with no problems.
MAXSE5SPD
Sep 17, 2022 04:00 AM
pears
Sep 18, 2015 05:25 AM
