weird amp problem
Old May 21, 2003 | 12:11 PM
JDM4LIFE's Avatar
weird amp problem
after shortly hooking up the wires to my amp/sub combo to test they work okay, i've run into a weird situation that's got me stumped. i turn on my car and i can get bass going through my subs. however, when i turn the gain past a certain point on the amp, it just emits this tremendously loud signal until i turn the gain back down. i noticed the loud signal goes higher and lower depending on what i've got the bass eq set at. i dunno what kind of a difference that should make and why. i have an mtx 6500d mono sub amp and two infinity kappa perfect 12s (i've only got one hooked up right now while testing). anyone have a clue as to why my amp would be doing this??
Old May 23, 2003 | 08:08 AM
JDM4LIFE's Avatar
bump
Old May 23, 2003 | 01:13 PM
erty67's Avatar
Decal Specialist
what is your input source to the amp and how is it grounded?
Old May 23, 2003 | 08:52 PM
JDM4LIFE's Avatar
it's source is the rcas from the receiver, and is grounded from the same spot as my 4-channel amp that is (which is working fine...). i blew a fuse, so i can't check it until tomorrow when i buy another. however, i'm gonna try the front/rear rca inputs to the sub amp and see if that changes things (probably not, but who knows).
popdedop
Sep 11, 2015 11:17 AM
bennuss
Sep 11, 2015 05:55 AM
