door panel off
Old May 23, 2003 | 05:07 PM
maxperformance's Avatar
door panel off
how do i get the front door panel off my 95 maxima
Old May 23, 2003 | 07:38 PM
erty67's Avatar
Decal Specialist
http://carstereohelp.com/stereoremovalNisMax0.htm
Old May 23, 2003 | 10:44 PM
foodog226's Avatar
I've tried to get my front door panels off, but I can't seem to get the ring around my door handle off. I'll start pulling on it, then it will seem like it's going to break. Is there any trick or tool I should use to get this piece off.
Old May 26, 2003 | 08:21 PM
erty67's Avatar
Decal Specialist
try carefully prying from the top with a screwdriver. once you get that part undone, the other two spots will be easy.
Old May 27, 2003 | 06:25 AM
jmax
Huh, and I thought it was the back clip that held it so tight. I might have to go take another look this afternoon if it's not raining.
Old May 27, 2003 | 06:48 AM
erty67's Avatar
Decal Specialist
yea, the back one is tight, but once the top one comes out it is easier to get out. at least it was for me good luck!
Old May 27, 2003 | 07:45 AM
Pearl96Max's Avatar
I tend to get a bit irritable
theres actually three of them, but as stated above once the top is out the others will be pretty simple. The top one as described is located about 85% towards the front of the car, use a flathead and go almost directly face down with it, pry slightly up and it will pop.
--Don
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
BobTX10
Oct 7, 2015 08:43 AM
lrb6805
Sep 24, 2015 05:03 PM
