Wires on Bose amp to tap for new Sub/Amp & where to bring power through the firewall
Old May 27, 2003 | 06:20 PM
swallac2
I need to tap a couple of wires off of the Bose amp. The first is for the remote turn in (sometimes called power antenna on head units). The second is one of the rear speakers to tap for signal.
If you could give me the wire colors that would be great. Also if you have any suggestions on where to come through the firewall with the power wire that would be great too.
Steve
Old May 28, 2003 | 10:58 AM
maximamaybe's Avatar
Look in the FAQs Studman put a great link in there with all the wire colors.
Old May 28, 2003 | 11:19 AM
MaxSE03's Avatar
Run the power wire through the hole at the drivers fender. Take out the inner fender trim plastic from above the wheel. You'll see a grommet that leads into the car. Make you a whole in the grommet and run the wire through.
Old May 28, 2003 | 04:41 PM
swallac2
Thanks maximamaybe, I couldn't find them and since search is disabled I was SOL, but I did find it on Studman's web page.
MaxSE03, thanks it makes it easier to have a heads up and something to look for.
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
mix master
Sep 4, 2015 05:50 PM
jfl330
Sep 4, 2015 01:44 PM
