Removing Rear Deck
Old May 29, 2003 | 08:51 AM
eperalta's Avatar
Removing Rear Deck
I was wondering if someone could direct me on how to remove the rear deck panel? I need to add some sound deadening material.
TIA
Old May 29, 2003 | 09:53 AM
Kojiro_FtT's Avatar
Re: Removing Rear Deck
Originally posted by eperalta
I was wondering if someone could diretc on how to remove the rear deck panel? I need to add some sound deading material.
TIA
What year max? If it's a 5th gen, then I took some pics of mine when I recently did it: Decklid fix. The only thing I skipped was removing the rear seat, which is easy. There are two pull tabs under the front of the bottom seat, pull them and the bottom comes out. Then there is one bolt holding the side bolsters on, can't miss them. I left the back of the seats on when I did it, but a few extra bolts and you could take them off too to get them out of the way.
Old May 29, 2003 | 10:10 AM
Blaxxxima's Avatar
!OG SNES OG!
Allow me:
http://carstereohelp.com/stereoremovalNisMax0.htm
Have fun
Mike
Old May 30, 2003 | 07:48 AM
eperalta's Avatar
Re: Re: Removing Rear Deck
Sorry, this applies to the 5th generation 2003 Maxima. I was wondering if the foam you used was Pink Panther? Please let me know, at your earliest convenience.
Old May 30, 2003 | 10:16 AM
Kojiro_FtT's Avatar
Re: Re: Re: Removing Rear Deck
I just used the foam pads they sell for beds. Go into Wal-mart or some equivalent and look around in the bedsheet/pillow aisles and you'll see it; sometimes it comes in yellow, too. It was $8.
Like I said, it was a little think and made it a PITA to snap the lid back in, so if you can find some thinner foam somewhere, like 1/2" or 3/4", it will make the job easier.
Old May 30, 2003 | 02:18 PM
WildmanAL's Avatar
I did this job myself. Check this site out http://zachaltman.hypermart.net/Rear-deck.htm
I have some pics of what I did on my cardomain page
http://www.cardomain.com/member_page...=313259&page=4
I also ported the rear deck and covered it with a bose grille. I went to Target and got this bed foam that is thinner than most and works the best. You don't want anything too thick because it will make the rear deck stick up. I shoved some stuff under the child safety hooks in the back to hold the deck down. You'll be amazed of how sturdy it is now.
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
doctorpullit
Sep 10, 2015 06:33 PM
