Radio Swap With 240sx
Yup.. i swapped may NON BOSE cassette player with a stock CD/AM/FM radio from a 95 240sx. Harness specs are the same so it was a direct swap. One problem is really bugging me, so any stereo experts please help. I turn the volume as far as it would go and it sounds like it its at mid way (doesnt sound loud). All speakers are ok and when i switched back to the maxima stereo everything works good. Im thinking i need an amp. Is there something im missing. the 240sx radio looks really nice and blends in well with the dash, and the built in CD player works great.
i apprecaite the quick repsonse. I did check all settings. I plated with fade and balance, but even if it is weaker then the max stereo it shouldnt sounds this low. I mean it sounds pretty low for maxed out volume. If i turn the air conditioner on i can barely hear 50 cents.
Originally posted by Kojiro_FtT
Maybe the 240SX had an external amp?
Thanks for the help and the responses
that what im thinking. I observed both stereos and noticed that the MAX stereo has heat sinks attached to the back, if im coreect this usually indicated a built in amp while the 240sx doenst. Will an aftermarket amp work on such an "OEM" environment???
i found one for 104 its a Pioneer GM-X374. wat do i need to install. I place quoted me 150 just to install and siad i need 4 new speakers. Heelllppp??
im used to pulkling out my panels.. amp will probly be under passenger seat but you have convinced me to by this product and crutchfield sells the amp install kit for 20 bucks so im jumping on everything rite now. Any more tips... Everyone thanks for replying.. great help
Oh and as far as "needing" 4 new speakers: eh. Try it, and then decide. Just be aware that there is the possiblity that the extra power could blow your stock speakers, depending on the volume that you play it at. You can always upgrade the speakers later. Those are also easy to install yourself. It's also easy to get hooked and buy a ton of car stereo stuff and next thing you know your wallet is empty.
can i keep the volumke at a low for now until i have money for the speaker upgrades????
Most major brands have amps with line-level input (also called speaker-level input).
Originally posted by jargoone
Uh, no, you're confused. Line level and speaker level are not the same. Line level inputs are driven by low-voltage pre-amp outputs. They are connected by RCAs, typically. Speaker level inputs are driven by speaker-lever (high voltage) outputs.
jmlee44
10-02-2022 02:13 PM
TallTom
50
07-08-2022 09:54 AM
