stereo reception - help please!
Old Jun 10, 2003 | 11:16 AM
jrklar's Avatar
I've had an ongoing problem with the stereo reception on my kenwood excelon receiver. i installed the unit about a year ago, and noticed poor reception from the start. i assumed it was just the receiver, but i checked all the connections and the reception got much better when i unplugged the antenna connector and replugged it back in. unfortunately, this solves the problem for about a week, and then the reception gradually gets bad again. once in a wihle, i'll start up the car in the morning, and it'll be good, but very rarely. any suggestions on where to begin? appreciate your help.
Old Jun 10, 2003 | 11:25 AM
hrygeek's Avatar
Did you hook up the Rem ant wire? If not, the Maxima has an internal ant amplifier that must be powered. Try that, hopefully that works.
Old Jun 10, 2003 | 11:30 AM
hrygeek's Avatar
when you hooked up the deck, did you connect the remote antennae wire? There's an internal antennae amplifier that must be powered. Try that. That's all I got.
Old Jun 10, 2003 | 12:31 PM
jrklar's Avatar
any idea how i can be certain it is connected? is it separate from the general antenna wire? thx!
Old Jun 10, 2003 | 12:51 PM
hrygeek's Avatar
It's a blue/white wire from the deck. only way to check is to pull the h/u. it should be labeled rem ant.
Hope it works
Old Jun 10, 2003 | 04:08 PM
hrygeek's Avatar
i apologize. i'm an idiot. it's not called the rem ant wire. it's the power ant wire. still blue/white.
Old Jun 11, 2003 | 06:36 AM
jrklar's Avatar
thanks man, i'll check it out.
Old Jun 11, 2003 | 08:44 AM
hrygeek's Avatar
let me know what happens
Old Jun 12, 2003 | 01:29 AM
thomasd cook's Avatar
No you need to hook your remote line from radio to antenae wire from wiring harness. Should be marked on wire.
chisam14
Nov 6, 2018 08:56 PM
leatherneck
Sep 30, 2015 09:16 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
