Wiring Kit Reccomendations
I have 2 JBL 1200.1 Amps.... And I need a wiring kit bad! Fosgate has one a dual amp wiring kit for it. I know Im going to need a deep cycle battery and a cap and i should be fine. I talked to some professional isntallers.... Will i be ok with just a dual amp wiring kit by fosgate? heres the specs...
two 5-meter (16.4-foot) purple Stealth patch cables
17 feet of 4-gauge translucent red power cable
3 feet of 4-gauge translucent ground cable
6 feet of 8-gauge translucent red power cable
6 feet of 8-gauge translucent ground cable
38 feet of 16-gauge speaker wire
platinum-plated fuse holder with 60-amp AGU fuse
platinum-plated fused distribution block with 30-amp fuse
platinum-plated ground distribution block
2 platinum-plated ring terminals
17 feet of 18-gauge tinned silver turn-on lead
16 spade lugs
16 female disconnects
wire ties
protective grommet
16 spade lugs
wire ties
protective grommet
2400 watts and only usin 4 guage? i use 4 gauge to run my 2 amps that almost total 1000 watts and 4 gauge was barley efficent enough with a cap. i aint no audio expert but i would go with 0 gauge to a distribution block that seperates to two 4 gauge wires or possible 2 gauge
trsandrew
04-08-2016 06:45 PM
Kyle Lee Cleveland
09-28-2015 07:58 AM
Pied
09-26-2015 03:29 PM
