98 Max Bose...Constant Faulty??
Old Jun 20, 2003 | 05:58 AM
elcid's Avatar
Ok, my radio died....got another eck of my buddy. But when I was testign for the constant and switched 12volt, I found that the switched is fine and give the proper voltage. But the constant only reads like 2volts when the car is off....Does that make sense? Will I have run a new constant wire? Is this normal for suck a low voltage, or is my constant wire or link faulty? And anybody have any idea where I can get teh color codes for the wires on the BOSE system? All I find is the chart for non-bose and people asking for the BOSE chart but with no reply.....HUge thanks as always!
Old Jun 20, 2003 | 07:30 AM
ny96max's Avatar
i would just run a new line off the ignition harness (fused 10amp) and be done with it!
Ant
Old Jun 20, 2003 | 07:40 AM
elcid's Avatar
My ignition wire is fine. It's the memory wire that's not I believe. I'm only getting like a 2volt reading on it...I think it should read 12volt? Thansk for the help, I really want to get this resolved
Old Jun 20, 2003 | 09:21 AM
ny96max's Avatar
ok, let me explain. On the main ignition harness of the car there will be about 6 heavy gauge wires in a harness. Im 99% sure the white/red will be your constant 12v. Tap that wire and run it to your radio. Make sure to use an inline fuse (10amp). You will have to drop the underdash panel to acess these wires.
Ant
Old Jun 20, 2003 | 09:42 AM
elcid's Avatar
I get it now....Thanks!! For real!! Hopefully this will work, I'll try it after work.
Ant
Old Jun 20, 2003 | 12:16 PM
ny96max's Avatar
no prob!
Ant
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
