Capacitor holes are stripped, cant tighten screws.
Old Jun 23, 2003 | 08:24 PM
D1NOnly34's Avatar
I dont know what happened, I guess it just happened out of nowhere, I didnt even realize it. I have a 1 Farad RF cap but I cant use it because the top bolts wont securely tighten into the holes, they will always stay loose. WHat can I do, teh cap is still good, is there anyway to fix this? =/
Old Jun 23, 2003 | 09:11 PM
jmax
Get the next larger size tap and tap it out. Then get bolts or set screws of the appropriate diameter and pitch.
Old Jun 24, 2003 | 08:09 AM
D1NOnly34's Avatar
What exactly do you mean by tap? You mean that the holes can be replaced? Where would I go about finding this?
Old Jun 24, 2003 | 08:27 AM
Unibomber's Avatar
to get mine off (becuse i had the same problem) i disconnected the battery then cut a slit with a hacksaw on the top of the damaged bolt (enuff for a screw driver to unscrew it) then took it off and got new matching bolts
Old Jun 24, 2003 | 08:28 AM
jmax
A "tap" may be used to thread a hole. Sears or any hardware store keeps many sizes in stock. I don't know if you have enough clearance on the blind side of the hole to tap it out. This is a fairly common problem with brass fittings. They are used instead of copper because they are harder but still have high conductivity. But compared to steal are quite soft. If you do have clearance on the blind side of the hole you may also be able to place a steel or brass nut back there to hold the bolt or set screw.
Old Jun 25, 2003 | 03:07 PM
CaLSoNiC
Soder?
Old Jun 25, 2003 | 03:22 PM
TAPOUT's Avatar
You will lose
The problem you have is very common. You have over tightened the screw, and no longer can you use it. You can't tap it right because it is lead,therefore to soft to hold. Most manufacturers of caps will repair it for a charge of about $35 bucks. That is far cheaper than replacing the cap. Call the Number on their website, and see what the going rate is.
Old Jun 25, 2003 | 03:45 PM
D1NOnly34's Avatar
I see, doh! Thanks guys for the help.
Old Jun 25, 2003 | 03:51 PM
jmax
- cheap *** cap!
Old Jun 25, 2003 | 10:11 PM
D1NOnly34's Avatar
Rockford Fosgate 1.0 Farad? Its nto THAT cheap, I thought it was pretty good. ANyways, I work at sears, so I got a couple of my friends to explain to me the whole tapping technique, it doesnt look easy, and could get quite costly.
Old Jun 26, 2003 | 03:27 PM
Maxima Dan's Avatar
Try a Helicoil.
Old Jun 29, 2003 | 06:58 AM
rickso03's Avatar
Re: Capacitor holes are stripped, cant tighten screws.
Someone mentioned using a Helicoil in the stripped holes, which is a good idea. One thing I thought of is to get two long screws (with the heads cut off) brazed/welded into the stripped holes. Now you'll have screw terminals instead of threaded holes.
Old Jun 29, 2003 | 11:36 AM
D1NOnly34's Avatar
Thats a very good idea, thanks!
rbarnes
Dec 31, 2015 06:29 PM
RealityCheck
Oct 2, 2015 06:34 PM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Noela
Sep 26, 2015 08:22 AM
