System Question....
Old Jun 30, 2003 | 09:05 AM
y2KAOSMax's Avatar
System Question....
For some reason my sub stops for a sec in songs that have a lot of bass.. Then its fine for the rest of the song.. I'm not sure if its the amp or the sub.. Any help would be appreciated....
Old Jun 30, 2003 | 12:10 PM
spirilis's Avatar
Sounds like the amp would be at fault... I doubt the subs themselves could cause that (unless they're seriously broken :P)
Perhaps the amps are overheating for a brief moment?
Old Jun 30, 2003 | 01:20 PM
CanadianMoFo's Avatar
This could be a ground problem. The ground isn't bad enough to prevent current being passed, but during heavy bass tones it needs to pass more current through and as a result of the poor ground shuts down. Comes right back on when the music is less bassy or is turned down.
Its worth the couple minutes it takes to re-sand the spot its grounded to and check the wire and ends.
CM.
Old Jun 30, 2003 | 01:50 PM
y2KAOSMax's Avatar
CM.
Yeah that makes sense.. I'm gonna check them as soon as I get off work.. Thanks guys for your help..
Old Jun 30, 2003 | 03:13 PM
reygarcia's Avatar
Loved by MrGone longtime
Could also be the amp going into protect mode.
Old Jun 30, 2003 | 03:57 PM
max'n out's Avatar
That don't happen for just one second.
Old Jun 30, 2003 | 11:04 PM
y2KAOSMax's Avatar
Of course I didn't mean a literal second.. I'm not going to time exactly how long it stops but it stops at a bass drop then kicks back in for the next one..
Old Jun 30, 2003 | 11:05 PM
y2KAOSMax's Avatar
I'm gonna have to look at it to see if its does.. Thanks for you response..
Old Jun 30, 2003 | 11:28 PM
max'n out's Avatar
It'll be longer than that too, Protect mode usally last for no less than 5 min.
Miket2006
Mar 1, 2021 03:55 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
RWCreative
Sep 21, 2015 11:01 AM
