Remote For Amp.....
Old Jul 30, 2003 | 10:27 AM
LEANNA's Avatar
Remote For Amp.....
I have installed an amp. and sub to my bose stereo using this converter I got, now I need some suggestions on the remote switch to turn on the amp. I used a switch with it's own seperate fuse, but the fuse keeps blowing. Anyone have any ideas what I can tap into for the remote so that it will go on only when my car is started????
Old Jul 30, 2003 | 12:05 PM
MIXXMAX's Avatar
Re: Remote For Amp.....
Usually, when a fuse blows, the amperage in the wiring is higher than the fuse rating of the fuse, or that there is a short somewhere along the path of the wiring. You may have to install a higher rated fuse so that the fuse will not blow. But, just my 2 cents, why do you need to remotely turn on the amp with an inline fuse? The remote wire carries a small amount of current that only sends power to turn on the equipment. The power wire is where all the higher amperage is.
Old Jul 30, 2003 | 03:21 PM
phenryiv1's Avatar
Mod her. Ate her.
I used the power (12v +) wire from a rear Bose amp. It is only on when the car is on and has worked for the last 6 months w/o a problem. The FAQs have a wire color code for the 4th gen. If that fails, post again or search in the test forum...
Old Jul 31, 2003 | 05:58 AM
LEANNA's Avatar
reply
Thanks for your response, I replaced my rear speakers w/ Rockfords. Does that mean my amp is gone??? I really don't know anything about stereo systems. My cousin hooked it up for me. I just want the damn thing to work so I can listen to my music!!
ToTheMax305
Sep 23, 2015 09:11 PM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
