Sub blown? Please help!
Old Aug 6, 2003 | 03:55 PM
RideTheMax's Avatar
Ok, here's the deal. I have bose system, two Rockford Fosgate 12's and big amp (I can't think of the name) Anyways, I noticed a major drop in bass the other day so I got out and checked things out. One of my subs is not hitting at all and the other hits just fine. I checked the connection at the amp, box, inside box at speaker connection. It's a dual ohm or whatever it's called, where the box wires hook up to the sub and then two wires run from one side of the sub to the other. Anyways, I checked all these connections and one was unhooked. I hooked it back up and nothing. I'm pretty sure it's hooked up right as it was once working and now it not, and only one plug was out. Is the sub blown? Wouldn't it still hit a little but sound like crap if it was blown? I plan on hooking up my JLw3 I have sitting around to see it that will work. (not that I plan on running one JL and one Rockford) Just looking for some ideas. By the way I also have two 30 fuses in the amp. I switched those around to see if it would affect anything, it did not. Any help will be much appreciated. Thanks. Sorry so long, just trying to be specific.
Old Aug 6, 2003 | 04:57 PM
Method Max's Avatar
Yea,"sounds" like its blown. However...if you're planning to run 2 different subs from the same amp and box, your impedence is going to vary on each sub.
One sub will hit hard while the other hits softer. Get 2 of the SAME subs!
Old Aug 6, 2003 | 06:15 PM
RideTheMax's Avatar
NO, I'm not planning on running two different subs, I was going to hook the JL just to test the wires, you know so if it works its definately the sub and not the wires or connection. Thanks for the help.
Old Aug 6, 2003 | 06:46 PM
Method Max's Avatar
Ohh, word. Yea wires usually never go out unless they're cut or melted. It's most likely the sub
Old Aug 6, 2003 | 08:01 PM
Parsec's Avatar
to test if all the connections inside the box are intact (in case a voice coil snapped or something), you can use a multimeter to check if the resistance at the "box wires" is correct.
Old Aug 6, 2003 | 09:40 PM
RideTheMax's Avatar
Swweeeeet! That's a little over my head though. I'm going to have to just try hooking up another sub. Thanks for the input, I'm just not electronically gifted. I'll figure something out.
Old Aug 6, 2003 | 10:18 PM
Method Max's Avatar
yea, your Ohms are going to be WAY different on a multimeter when testing if you have a blown sub.
Ohms and impedence are very hard to explain (in typing)....but - you might could just take it to a audio place and have them test the impedence. Then you'll surely know.
Old Aug 8, 2003 | 03:09 PM
RideTheMax's Avatar
Thanks for the help everyone. I figured out finally it was the one connection on the amp I forgot to check. Anyways, I do appreciate it.
Floktndr
Nov 30, 2015 07:48 PM
homewrecker
Sep 24, 2015 07:01 PM
TxBroncosFan
Sep 21, 2015 06:54 PM
Maxie40
Sep 14, 2015 11:28 AM
I<3 A32's
Sep 10, 2015 11:07 AM
