new amp and sub need some help
Old Aug 17, 2003 | 01:05 PM
Irish's Avatar
This is a democracy
i just bought my new amp and sub, they are both audiobahn and the sub is a 10" AW1006Q, its DVC, my amp is the A275HCT. its a 2 channel amp. the sub is weird, on each side there are 2 +'s and 2-'s
so that makes a total of 4 + terminals to the sub and 4-, how do i wire this up correctly to get all the power of the amp to the sub. if someone would like to tell me how to put pics up i can show u the sub and amp. thanks
Old Aug 17, 2003 | 01:39 PM
maximaseefu's Avatar
are you sure they don't go to the same terminal?
Old Aug 17, 2003 | 07:46 PM
Irish's Avatar
This is a democracy
no im not sure. this sub is confusing the h**l out of me
Old Aug 17, 2003 | 08:19 PM
AscendantMax's Avatar
never seen a sub with that kind of terminals before.
Old Aug 17, 2003 | 11:56 PM
doesn't it come with manual? i have the audiobahn alumapro 10 subs and my terminals don't look like that. what is the impedence of the subs?
Old Aug 18, 2003 | 09:06 AM
Irish's Avatar
This is a democracy
the sub didnt, and thats exactly what my sub looks like. the sub is 1 ohm i think, maybe 2, fosgate fan, do u know? i bought the sub from a wholesale internet site, all they gave me is the warrenty papers and an invoice and a sticker.
Old Aug 18, 2003 | 12:34 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Each side is the same coil. What you need to do is meter each side to find the resistance then connect accordingly. If each coil is say 4Ohm and you need a 2Ohm load you will connect + to + and - to - , IF you need an 8Ohm load then you will connect + to - then one + and one - from each side will go to your amp. Same theory is broken down if each coil reads 2Ohm, etc.
--Don
Old Aug 18, 2003 | 03:02 PM
well, that pic is the AW1006T and it's dual 4 ohms. you said have the AW1006Q , you sure that's the right model #? i can't find anything about that sub. only found info on the AW1006T. i've looked at crutchfield and audiobahn's site.
Old Aug 19, 2003 | 08:59 PM
Irish's Avatar
This is a democracy
http://7925.adahost.com/computer/ind...talog22_0.html
there is the link the the site that i bought it off of, it says its 3 ohm or 6 ohm, will this work with the amp that i have? do the ohms have to match up or can i wire the sub down to 1 ohm, cause i know for sure that the amp is 1 ohm stable. im kinda a newbie with the subs, i know how to wire every thing from the H.U. back but this sub/amp combo is really screwing up everything i thought i knew.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
