Need advice on Bose upgarde
Old Aug 19, 2003 | 02:55 PM
jsohn's Avatar
I have a 2002 SE and I have the Bose unit. I would like to uprade the stereo, but would like to keep the head unit in place. What do you guys recommend to get the best sound out of this crappy system? What kind of speakers should I get? or do i need to get a apmplifier? I am clueless when it comes to stereos.
Thanks.
Old Aug 19, 2003 | 07:27 PM
maximaseefu's Avatar
you can add a sub and amp.
Old Aug 20, 2003 | 12:35 AM
TAPOUT's Avatar
You will lose
You can replace everything, fronts, rears, amps, subs, you name it...You just need to get a couple of good line-level converters and start swapping. Best bet is to do it all at once because an aftermarket amp will not run your Bose speakers without problems, and if you swap just the speakers, they will not work right with the Bose amps. Look forward to spending at lest $1000 to do it right, $2000 to really have something, and $5000 for bragging rights.
Old Aug 20, 2003 | 11:16 AM
jsohn's Avatar
Thanks for the advice.
Old Aug 20, 2003 | 10:20 PM
kwd2kSE's Avatar
I've added the equipment per my sig to the stock Bose headunit, and also have not changed the door speakers. I plan to change both of these later, but for now, the upgrades sound much, much better than the original tweeters and sub.
Mike
Old Aug 21, 2003 | 12:25 AM
esc92's Avatar
I'm going to be purchasing a 2K Max and I to would like to upgrade the Bose system without replacing the headunit. Someone was talking about a good line-level converter...how can u hook that up to the Bose headunit and can u direct me to some more info on this converter?
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
dshinn
Sep 26, 2015 08:07 PM
