Tweeters in the A-Pillar
Old Aug 26, 2003 | 08:12 AM
danbortz's Avatar
hey guys...
i'm looking to upgrade my system by putting in tweeters in the A-Pillars by the windshield, i have a 99 Black GXE...
what years had the factory tweeters in the pillar and where would you guys recommend i pick up a pair of tan ones?
also, what tweeters would you guys recommend that would fit easily and sound good??
THANKS A LOT!
Old Aug 26, 2003 | 11:04 AM
max5spd's Avatar
Says.."No mo Maximas for me!"
95-96 Maximas and 96-97 I30s.
I went the other route and added tweeter to the door and used new pillars to cover the old tweeters.
I have tweeter pillars for sale if you're interested.
Old Aug 26, 2003 | 01:31 PM
danbortz's Avatar
how did you add them to the door panels??
would i have to get new door panels to install the tweeters??
Thanks...
Old Aug 26, 2003 | 07:10 PM
max5spd's Avatar
Ok, let me rephrase. I added the tweeters to the sail panel on the door by the side view mirrors, not actually to the door panel. Sorry about that. There are pics of where I mounted the tweeters on my homepage.
Old Aug 26, 2003 | 10:15 PM
Weasel's Avatar
My installer told me the system will sound better with the tweeters in the door panels, for optimal sound quality the midbass and tweeter shouldn't be more than ~18 inches apart.
Old Aug 27, 2003 | 08:22 AM
danbortz's Avatar
anyone out there have a write up or pictures about how to install a set of tweeters into the door sail panels by the window/mirrow??
do i need to worry about tweeter depth etc in the panel??
do the tweeters come with crossovers needed for the install?? i have Boston Acoustics running from an amp under my passanger seat in the doors now, how would i go about hooking the tweeters up??
Thanks for all the help guys, this is the first time i've ever worked with tweeters and i'm looking for the best sound set up i can get.
Old Aug 29, 2003 | 05:48 AM
JMF's Avatar
JMF
danbortz
You shouldn't need a writeup for that. It should be really easy.
Pull back the interior sail panel, you can see that there isn't much room for a flush mount tweeter, but there is plent of room for surface mounts and wiring.
I don't know much about your setup, but most tweeters (sold separately) have built in X-overs. If yours have crossovers, just wire them to your door speakers.
Here's another question:
I just bought a set of CDT CL-61s. I plan on surface mounting them on the aforementioned "interior sail panels" (beside the sideview mirrors). Should I mount them "straight" or angle them toward the driver and passenger?
Old Aug 29, 2003 | 09:28 AM
max'n out's Avatar
Idealy the tweet should be close together yet, nothing is ideal. With a 12db crossover you can easyily run them further apart, not to mention todays speakers are ment to be run way off axis.
Old Aug 29, 2003 | 10:13 AM
JMF's Avatar
JMF
That's good to hear. I don't want to get blasted with the tweeter, and I don't want to cut the door panels (resale issues-I'll take the gear out)
95naSTA
Sep 21, 2015 06:50 PM
MikesChevelle
Aug 9, 2015 11:50 AM
Y2KevSE
72
Aug 4, 2008 08:21 PM
Loe max
Jan 25, 2001 07:48 PM
maxz32
Dec 25, 2000 09:55 AM
