which way to face the sub
Old Aug 26, 2003 | 11:54 AM
krmaxima's Avatar
i have a 15 inch and was wondering which way to fire it up down or toward teh trunk or towards to front? which will sound the best
let me know
thanks
Old Aug 26, 2003 | 04:48 PM
D Love's Avatar
Re: which way to face the sub
let me know
thanks
I've always heard that is sounds best when fired towards the rear of the car.
Old Aug 26, 2003 | 06:03 PM
AscendantMax's Avatar
best way to know is to go out and try each setup to see how you like it. firing towards the front tends to be more accurate while firing towards the rear more boomy. plus it's a bit louder if you fire towards the rear.
Old Aug 26, 2003 | 08:56 PM
Kojiro_FtT's Avatar
Actually I've heard the opposite. Fire towards rear is more accurate and forward is boomy. Something to do with the length of the wave and the distance it travels to your ear, I dunno. But I agree, just try each one and see how it sounds to you. Then go with the best one. Who knows, maybe your particular sub in your car will sound best to you while firing up
Old Aug 26, 2003 | 11:12 PM
does your system seems louder with your windows down? 'cause on mine, it sounds a bit deeper with the windows down.
Old Aug 27, 2003 | 07:48 AM
Gjohnson's Avatar
Yes, I've always figured it had to do with the air pressure or something. So I always bumb with the windows down.
Old Aug 27, 2003 | 05:45 PM
Gooey's Avatar
hmmm i thought it was louder with windows up you feel more vibrations i like to get vibrated off my seat
Old Aug 27, 2003 | 05:58 PM
mb1's Avatar
mb1
i've tried every way, and towards the back works the best.
Old Sep 12, 2003 | 02:44 PM
keanders21's Avatar
I have a 15" solo baric L5 and it sounds a lot better facing the back of the trunk. Also the closer I have it sitting toward the back, the better it sounds.
Old Oct 3, 2003 | 07:30 AM
bigcozz's Avatar
Point it back its the best and if you have a wedge push it towars the back of your rar seat this way whole trunk in like a big box
Old Oct 3, 2003 | 08:03 AM
Audtatious's Avatar
Bandwagon Lover
Pointing the sub towards the rear can give you a DB increase due to boundary effects and can increase SPL by as much as +6db. This benefit is limited to frequencies in which the distance from the driver to the boundary is less than 1/10th of a wavelength. So, in a Maxima, dependant on the box and location of the sub, you would have 2' +/- from cone to the back of the trunk which means the increase will effect frequencies where sound waves are 20' which is around the 70hz range ( 20hz propagates in 56.6ft and 100hz at 11.32ft ).
Pointing the sub into the cabin negates any of these gains...Of course, the car would probably be quieter since you won't have a sub trying to blow off the trunk
psing23
Nov 30, 2000 10:30 PM
bjf
Nov 28, 2000 03:09 PM
