CD Changer Power Source
Old Oct 3, 2003 | 06:35 AM
keanders21's Avatar
Does anybody have any suggestions of the best place to get 12 volt power for a trunk mounted cd changer?
Old Oct 3, 2003 | 06:42 AM
Dohcser's Avatar
Best and proper way to do it is to run a dedicated 12V with an inline fuse.
Old Oct 3, 2003 | 07:34 AM
keanders21's Avatar
Do you know from where in the car to tap into that power?
Old Oct 3, 2003 | 07:52 AM
Dohcser's Avatar
How many wires does the CD Changer have, what kind of Changer is it? You will definately want to hook it up to your remote power wire, but to properly do this you should do it with a Relay. So when your radio turns on it sends a signal to the relay then the relay switches on and sends power to the changer.
Old Oct 3, 2003 | 07:53 AM
Dohcser's Avatar
You couls also tap it off of your amp in the trunk if you have a BLOSE system.
Let me know how you want to do it and I will give you the procedure.
Old Oct 3, 2003 | 08:09 AM
keanders21's Avatar
It is a pioneer CDX-P1280 and it's controlled by my pioneer HU by A IP-Bus cable. It just has three cables, the IP-Bus Cable, the ground lead and a 12v power lead with a fuse.
Old Oct 3, 2003 | 08:41 AM
Dohcser's Avatar
Does the 12V lead ask for a constant 12V or switched/ignition 12V?
Old Oct 3, 2003 | 08:43 AM
keanders21's Avatar
it asks for constant 12v
Old Oct 3, 2003 | 09:32 AM
Dohcser's Avatar
You can tap into the constant 12V of your bose amp.
Old Oct 3, 2003 | 09:36 AM
keanders21's Avatar
I don't have a bose amp. I have a sony amp that I have powering my kicker solo baric.
Old Oct 3, 2003 | 10:12 AM
Dohcser's Avatar
If it is asking for constand 12V then just hook it up to your amp's constand go right on the terminal. This is incase you did not want to run another dedicated power wire from your battery.
Old Oct 3, 2003 | 11:09 AM
keanders21's Avatar
alright thanks!
aw11power
Oct 10, 2021 04:57 AM
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
