Bose HU Screw Removal?
Old Oct 5, 2003 | 10:46 PM
meanbean's Avatar
I have my dash completely disassembled but cannot remove the screws attached to the Bose HU on the mounting brackets. I have tried WD-40 but the screws don't give. It's as if Nissan never wanted anyone to remove the Bose HU from the brackets. Anyways, I will strip these screws if I keep going this way so I wanted to know if there is any trick to removing these stupid screws. My last resort it to cut them off but I hope it doesn't come to that. Any help would be appreciated.
Old Oct 6, 2003 | 12:27 AM
kgb006's Avatar
i had to drill mine out.
Old Oct 6, 2003 | 06:21 AM
Dohcser's Avatar
They are litterally impossible to get out, I was lucky with mine because I used a commercial screw gun with a carbide tip, but on other that I did you do have to drill them out.
Old Oct 6, 2003 | 09:41 AM
meanbean's Avatar
Looks like I have to do it the hard way. Thanks for the help.
Old Oct 6, 2003 | 09:47 AM
RMAX54's Avatar
I was able to get mine out with an impact driver. The tool looks like a screwdriver, but turns the screw as you push (or pound) it into the screw.
Lots of phillips head screws on motorcycles are just as tough to get out; that's why I have the impact driver - left over from my two wheeler days.
Old Oct 6, 2003 | 10:37 AM
Kojiro_FtT's Avatar
Try tapping them with a hammer to free it up before unscrewing. I got a few out this way, had to drill the last one tho. Good luck.
Old Oct 6, 2003 | 02:19 PM
1MAX2NV's Avatar
Impact screw driver works. You could also use those offset screwdriver, since you get more leverage with those. Or maybe one of those screw bit that you can put on a rachet. You should just need more force and it's hard to do with a regular screw driver.
Old Oct 6, 2003 | 04:07 PM
ny96max's Avatar
usually one or two good wacks with a screwdriver and hammer does the trick. Make sure you press firmly down as you unscrew them or else youll have stripped heads and will have to drill them out.
Ant
Old Oct 6, 2003 | 06:29 PM
SuperChris's Avatar
Infiniti 35 Double G's
if all else fails, the Bose HU....after an hour of f*cking around with those screws, i just destroyed the HU; screws were real easy to remove after that.
Old Oct 7, 2003 | 01:12 AM
meanbean's Avatar
Thanks for the suggestions everyone. Looks like I may be able to get these screws out now. SuperChris, your too funny man. I already had to stop myself a couple of times from almost doing the same thing. Hopefully, I won't need to resort to that. Anyways, wish me luck.
Old Oct 7, 2003 | 06:31 PM
RMAX54's Avatar
LOL - thinking of the hundreds of times that I had to grit my teeth to not do the same thing to computers (usually somebody else's).
Old Oct 9, 2003 | 06:48 AM
Supa Lao's Avatar
Try using a long screw driver and hammering it down. Then try and tighten the screw in some more (seems like it breaks the glue or whatever nissan uses to keep the screw from moving) Then just unscrew it out
Old Oct 11, 2003 | 08:56 AM
DaddyMac's Avatar
I got them off with a regular screwdriver, just make sure the tip is good and put some muscle into it. I'm not saying that it was easy, but it is possible.
I'm sure the impact driver will work too.
Old Oct 11, 2003 | 09:26 PM
SuperChris's Avatar
i didn't realize until i came to this board that i had destroyed something that woulda been worth $$$$$...somebody here might've needed it.
Old Oct 12, 2003 | 02:42 PM
sk24iam's Avatar
I'm having the same problem right now and it's really frustrating me.
Old Oct 12, 2003 | 02:44 PM
sk24iam's Avatar
How do I drill it out?
Old Oct 12, 2003 | 03:08 PM
Supa Lao's Avatar
I use a thing called a unibit and attaches to my screw gun
Old Oct 12, 2003 | 04:01 PM
sk24iam's Avatar
I'm not having much success. The two I dirlled through are completly stippsed and seem to have just been widened. I tihnk I will just bring the bracket to a shop to take out the screws. What kind of shop does this and where can it be done?
Old Oct 13, 2003 | 07:03 PM
orgasmicNYC's Avatar
Diamond tipped heads and keep screwing and applying pressure until they come out. They will, they always will!
Old Oct 14, 2003 | 04:04 PM
sk24iam's Avatar
I'm in desperate need os getting these screws out, any ideas? SHould I jsut buy ne brackets?
Old Oct 14, 2003 | 04:17 PM
Supa Lao's Avatar
Try using this unibit tool, it works:
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
sliptap
Sep 30, 2015 05:57 AM
jaydot901
Sep 29, 2015 01:18 PM
Redfox
Sep 28, 2015 10:41 AM
