Wheel Mounted Audio Problems
Old Oct 28, 2003 | 11:03 AM
max 01's Avatar
Has anyone had a problem with the switch on the wheel not functioning properly. It can really only be the spiral wire or the switch. The dealer didn't know and I took it apart and everything seems tight- Is it covered under the 5/60 because the wiring is part of the airbag harness $280.00. It seems to work if I turn the wheel to the 2 o'clock position. Has anyone any experience with this problem? It is intermittent so of course when I pulled in the pk lot of the dealership it worked fine. FYI, if your in NJ Lynnes Nissan West is hands down best dealership around- customers service and their attitude is great.
Old Oct 28, 2003 | 11:07 AM
VMAXiMA2001's Avatar
I had the same problem about 6 months ago. It worked on and off (would always work when I would get to the dealership too). I told them the problem and they replaced it with a new controller (so it is covered under the warrenty). So far so good, now if they could just fix the rattles and squeaks I'll be happy.
Vinny
Old Oct 28, 2003 | 11:22 AM
max 01's Avatar
Thanks Vinny...
So that solved it? Just the little $80 switch? I'm beyond the 3/36 but I could try it. Since I wigled the wires though it seems to be more on then off. Great reply though- thanks...if you have any other questions email me at davidpcs@optonline.net I know the max very well.
Vinny
Matt93SE
May 24, 2019 02:58 PM
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
Slamrod
Aug 10, 2015 12:33 PM
