LED help?
Old Oct 28, 2003 | 09:53 PM
96shogunmax's Avatar
LED help?
Foward (supply voltage) 3.7 typ.
4.5 max.
Foward current 20mA typ.
30mA max.
2600mcd
468 typ - peak emission wavelength(nm)
viewing angle - 30
What kind of resistor do I need? This is for my harlan switch. Thanks, Wayne
Old Oct 28, 2003 | 10:55 PM
Nismo's Avatar
im thinking 400 ohms
Old Oct 29, 2003 | 04:52 AM
So whats with the 1/4w , 1/2 w...on the package? Some say 1/4w and some say 1/4w
Old Oct 29, 2003 | 07:06 PM
Nismo's Avatar
I use 1/4 watt. the 1/2 watt are huge resistors like 1k ohms
Old Oct 29, 2003 | 09:36 PM
jmax
Other than a resister you can wire up a few of the LED's in series to get a total drop of whatever your engine on voltage is. 3 LED's will probably work but may need 4. Depends on how sensitive they are to overvoltage. The one's I am currently playing with are labeled I think 2.2 volts max but seem happy with 3 volts, or a pair of AAA batts. That is another option - just use a seperate battery power supply.
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
lrb6805
Sep 24, 2015 05:03 PM
