Need help with a single subwoofer and 2 amps!!!!
Old Oct 31, 2003 | 10:29 AM
mitch33x's Avatar
How did you secure the box, so it doesnt slide around? I have a single 10inch, and I'm just looking for a good way to secure the box, without it looking like ****.
I also have two amps, one of them I just attached it to the back of the sub box, and I dont know where to put the other one. I need some ideas...
also... happy halloween!
Old Oct 31, 2003 | 11:58 AM
maximamaybe's Avatar
I just used an L bracket from home depot.
Old Oct 31, 2003 | 04:17 PM
Parsec's Avatar
You can mount the amps on the metal sheet behind your rear sheets. As for securing the box, you should do like maximamaybe said and buy some L brackets from Home Depot (about a buck or 2). You may want to line the bottom of your trunk with a floorboard before doing that.
Old Oct 31, 2003 | 05:00 PM
AscendantMax's Avatar
i never had problems with my sub box moving around in my trunk. i guess it depends on the shape of the box itself.
Old Nov 2, 2003 | 08:41 AM
mitch33x's Avatar
The sheet behind my rear seat is made of plastic, amp cant go there
As for the box, I will try the L brackets
Old Nov 2, 2003 | 11:42 AM
can you mount each amp on each side of the box?
Old Nov 2, 2003 | 02:29 PM
mitch33x's Avatar
the box is small, the amps will not fit on the side
Old Nov 2, 2003 | 02:34 PM
SHO92's Avatar
One word...
Fiberglass
You know you want it. And your car will smell like "custom" for a few weeks afterwards.
Old Nov 2, 2003 | 10:32 PM
i think that's a bit too much work than what he's asking....
Old Nov 2, 2003 | 11:48 PM
SHO92's Avatar
Yeah, it's a lot of work, he's seen all the stuff I've been doing over the past year, LOL. I'm just giving him a hard time. Steve and I will figure out something to do I hope.
Old Nov 2, 2003 | 11:54 PM
mitch33x's Avatar
Old Nov 3, 2003 | 10:49 AM
KsuMax's Avatar
Cheesing away...
For my box, I first lined my trunk with a board, to make the surface flat, then I bought some velcro from home depot and put it on the bottom side of my box. I didn't put any on the floor, the velcro on the box grips good enough, and my box has never slid around. My amp is also mounted on the back of my seats.
Old Nov 4, 2003 | 03:26 PM
mitch33x's Avatar
good idea using velcro, I will give it a shot
Old Nov 4, 2003 | 06:58 PM
maxcosity's Avatar
if you use brackets and bolts, get locknuts... TRUST ME, anything else WILL come loose..
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
