My Subs sound like crap.....
Old Feb 21, 2001 | 04:34 PM
SilverBullet98's Avatar
I have two MTX 5000 and a Sony Amp ( 1000 watts I think )
Whebn I crank it up.....it sopund horrible, the bass isnt deep and low....its poppy like....( very hard to explain )It sounds really bad when it hits, The subs are pretty new, and they re not shot.....Is their anything I could do to make it sound better ??? The whole car rattles and vibrates, so that has something to do with it but the subs dont hit low at all !!
Please Help !!!!!
Old Feb 21, 2001 | 08:10 PM
94SUPERMAX's Avatar
Try adjusting your gain control you may have it too high.
I don't know if there are any other adjustment's you can make on the sony amp see if it has a Low Pass Filter. How do you have your subs hocked up?
Old Feb 21, 2001 | 10:40 PM
Nismo's Avatar
could be the enclosure. does it sound like a buzzing chattering sound? what about the Xover freq. or bass boost? how are all your settings are on the amp?
Old Feb 22, 2001 | 06:18 AM
CanuckAMP's Avatar
Check your crossover settings and your gain control. Your gain control should not be all the way up in fact at about 2/3 or higher it will probably start to distort the sound of the amplifier. If you have a low pass crossover on that amp make sure it's engaged and that it's set to around 80-120 Hz. What is the stereo RMS power rating on your Sony amplifier?
Also are you using the factory stereo headunit or an aftermarket one?
Old Feb 22, 2001 | 12:39 PM
I have Pioneer Head Unit, and the Amp is the Sony XM-2252HX....I realy dont know very much about this stuff...I know their are a bunch of settings on the amp...I doubt I have them in the right spot...I have a Level, Low Boost, Cut off Frequency, and a filter switch ( with Low Pass and High Pass )also...Hi Current/Voltage switch....Maybe I have these at the wrong settings...Can maybe someone tell me where I sould have thses set ??? Thanks A lot in advance if you can.....
Old Feb 22, 2001 | 12:43 PM
CanuckAMP's Avatar
I know someone that can probably help you set that up. I'll send you his email address.....
Old Feb 22, 2001 | 03:40 PM
Thank You .......
Old Feb 22, 2001 | 10:11 PM
SWEETSOUND2001's Avatar
email me..i can give you some good links how to tune your system and peep my page too. Laters. Where are you from. Maybe i can help you tune your system.
Old Mar 14, 2001 | 09:08 PM
93 SE's Avatar
how was that problem fixed cuz i just installed 2 12" mtx subs,and a new sealed box..its sounds weak...
Old Mar 19, 2001 | 03:51 PM
well....actually, the problem wasnt fixed. I tried adjusting the settings on my amp, and HU....but it still doesnt sound very good...But, I'm broke so I guess I jhave to live with it.....
Old Mar 19, 2001 | 09:15 PM
Matt93SE's Avatar
STFU n00b!
which direction are the subs aiming?
what size enclosure is it?
what size battery cable are you using?
do your headlights dim very much when you crank it up?
are there peak/clipping lights on your amplifier? if there are, do they light up when you have it cranked up that loud?
start there, and I'll see if I can help.
Old Mar 20, 2001 | 01:08 PM
93 SE's Avatar
very odd...what happen to me was i put new subs in [sealed box ,subs facing upward,amp bolted on side of box]it sounded weak then i put old subs back in they were weak...so i figure amp has to be level instead of side ways i was wrong..so im upset.. now i put new subs in and now it works im happy...i think it was the connection cuz it was the only thing i touched
Mahmuth
Aug 16, 2024 08:23 PM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Redfox
Sep 28, 2015 10:41 AM
