Help- Viper shock sensor adjustments
Old Nov 12, 2003 | 12:26 PM
Nismo's Avatar
I cant seem to get mine to work how I want it. when I set it sometimes, it will be so sensetive to taps on the hood yet it wont go off if I pound the doors. I cant seem to get it to work how I want it which is to warn when you knock on it but set off when you hit it harder.
Where sould the sensor be mounted? I have it zip tied to a wire harness right now.
Whats the proper way to adjust it, do I simply turn the screw?
Where do you have yours mounted and how is your **** adjusted? ?
Old Nov 12, 2003 | 05:59 PM
Nismo's Avatar
Help, Don or any alarm experts here?
Old Nov 13, 2003 | 06:52 AM
Supa Lao's Avatar
When I install alarms. I either have the shock sensor zip tied to a big bundle of wires under the dash or if there's a spot, I'll zip tie it to a piece of metal. As for adjustment, turn the screw to the right to make it more sensitive and left to make it less. When I test for shock sensor, I just smack the front windshield to see if I get an away warning. Then I go to the rear windshield and do it again.
Old Nov 13, 2003 | 08:31 AM
Igor911's Avatar
Mine is all the way up and wont go off if I knock. It only goes off on hard hits
TallTom
57
Oct 14, 2025 05:16 PM
aw11power
Oct 10, 2021 04:57 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
zmcneely13
Sep 26, 2015 02:26 PM
