Help with wiring Preouts to Bose amps!
Old Nov 13, 2003 | 06:43 PM
johnnyo319's Avatar
After reading some of the threads about whether or not to buy the Bose adapter, i'm going to try to save some cash and cut some RCA's up and connect them from the Preouts from my Alpine deck to the speaker ins behind the dash..
What i'm wondering is: I don't know much about RCA's but are there two wires in them? So one would be the positive and one the negative? Or are RCA's just one wire. So in order to connect the Front Left RCA on my unit out to the left front speaker, i would have to cut a RCA and find two wires inside it (+ & -)? Is my thinking all off? For those who have tried it, please let me know how you connect a new deck to a BOSE system.
i'm doing it for a 98 GLE btw. Please help..
Old Nov 13, 2003 | 07:16 PM
nadir_s's Avatar
vicodin ... gift of life
RCA's are made up of two wires... positive, negative.
Wait, why do you need to cut? Just get the $5 wiring harness.
Old Nov 13, 2003 | 07:23 PM
EriCCirE's Avatar
Hes trying to save cash
Old Nov 13, 2003 | 09:12 PM
johnnyo319's Avatar
is there a harness? i never seen one. i should look for one. anyway, do you know which is positive the middle or the outer?
Old Nov 13, 2003 | 09:29 PM
nadir_s's Avatar
it should be the middle one
Old Nov 21, 2003 | 12:13 PM
Drew96I30's Avatar
yea, middle positive...outside ground
Old Nov 21, 2003 | 01:29 PM
nadir_s's Avatar
lol, i am doing the same thing for my new Pioneer Premier unit.
I just went and bought some Monster cables... gotta cut em up now. Let me know how yours works out.
Old Nov 21, 2003 | 06:08 PM
johnnyo319's Avatar
I did it last week and posted the results in another thread. ANyway, when i did it i used some cheap RCAs because i was gonna cut them and was just testing it for the first time so i didn't want to waste money on monsters. Well when i did it, I would hear a pop noise from the speakers everytime i would turn off the Alpine, turn the volume all the way down, and when i change from CD to Tuner.. I don't know if this result varies from deck to deck or maybe from the volts of the outputs (4v), but i'd be interested to know your results..
Old Nov 21, 2003 | 06:36 PM
nadir_s's Avatar
alright sure, i hope u don't mind to wait till monday or tuesday... i intend to do it then. Actually, I went out to the local electronics store and bought monster cables for $10.99. I'm going to cut them up right now and make sure they have the positive/negative wires... i wasn't sure because they had some mono cables there.
I'll definately let you know. My specs manual says
Preout max output level/output impedance
2.2 V/1 kΩ
Old Nov 27, 2003 | 09:08 AM
nadir_s's Avatar
I have the same POP sound... did you fix it yet? Someone said it was due to bad grounding... and I know that I didn't do a great job or even tested a ground point... just sorta stuck it there. I gotta see if that helps.
Did you do anything to get rid of it?? I followed the same route you did with the RCA to preouts. Thanks!
Old Nov 27, 2003 | 10:40 AM
johnnyo319's Avatar
I didn't keep it connected to the spliced RCAs. I just wired as if i didn't have BOSE. (speaker outs to speaker ins) The sound is not bad, however i do hear slight hissing at the lowest volumes and the volume is louder than regular. When i turn it to volume 1, its low but not a normal 1, then at 2 it increases a lot, and at 3, it would be pretty loud, 4 would be bumpin.. I hear wiring this way could blow the speakers easier, but i guess that would depend on the users carefullness when turning the volume up...
Old Nov 27, 2003 | 11:16 AM
nadir_s's Avatar
how did you ground your harness/headunit/speakers??
Don and others are convinced that I didnt' ground it properly... i am goin to take it apart in an hour and use a voltmeter to find a proper ground point. I'll get back to you in this thread to see if it works.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
