Amp problem...plz help
Old Nov 17, 2003 | 09:11 PM
hollaatchaboi's Avatar
Hi...I have 2 12" subs and an mtx amp. However, it seem that one of the channels is losing power. So i would like to know, what can i do? Is there some way to use both subs on 1 channel? What does it mean to bridge the amp and how do you do this? Thanx
Old Nov 17, 2003 | 09:29 PM
kgb006's Avatar
you need to run your subs in a parallel [IMG]http://www.termpro.com/articles/images/image34.gif
Old Nov 17, 2003 | 09:39 PM
Conrad283's Avatar
I need a truck
fixed
Old Nov 17, 2003 | 09:59 PM
so run my subs in parallel and connect to the working channel? is there anything else i should know? thanx.
Old Nov 17, 2003 | 10:26 PM
kgb006's Avatar
Originally Posted by Conrad283
fixed
thanx.. i spend 20 mins trying to post that pic
AscendantMax's Avatar
more specs on the subs and amp would be helpful
kgb006's Avatar
what subs/ amp do you have >?
Old Nov 17, 2003 | 10:39 PM
i have a mtx 2160 amp.....2 mismatch subs.....1 polk ex 12 and one kenwood. Both subs are 4 ohms and 600 watts.
Old Nov 17, 2003 | 11:32 PM
kgb006's Avatar
if your amp is 2ohm stable you shouldn't have any problems
Old Nov 18, 2003 | 10:02 PM
jmax
Different subs will have different output. That is why nobody mixes speakers that will play the same frequencies. Did I say nobody? I meant nobody with common sense.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
