Calling all Alarm Experts!
Old Nov 21, 2003 | 12:14 PM
amr1776's Avatar
I just bought an ASC 3000 alarm and remote starter...it came with wiring diagrams and all but I'd like to find some more detailed instructions on general car alarm installation and putting alarms in the max...can any experts recommend some good books or web sites? thanks!
Old Nov 22, 2003 | 01:33 PM
futemv's Avatar
I'm no expert on it, but I'm trying to figure out the installation of my Audiovox aps996 alarm/remote start that I just bought. The site I've found most helpful so far is www.the12volt.com. It'll have a bunch of links to other decent sites too.
Old Nov 22, 2003 | 05:21 PM
amr1776's Avatar
Does anyone know if there are any good write-ups on alarm installation in the 4th gen?
Old Nov 22, 2003 | 06:58 PM
Supa Lao's Avatar
There's no really write-ups on alarms. The only thing you can get is a tech tip. That tells you what color wires does what(and the polarity) and where it is located. I don't have the tech tip on hand but I know I can get it. If I remember correctly, I think someone posted it a few months back. Might want to try a search on it
Old Nov 22, 2003 | 10:07 PM
C3nthusiast's Avatar
1997 Nissan Maxima wiring
12volts wht/red - wht/pur + ignition harness
Starter blk/yel - blk/wht + ignition harness
Second Starter grn/blk - red/blu + ignition harness
Ignition blk/wht - blk/red + ignition harness
Accessory red/yel - red + ignition harness
Second Accessory blue - wht/blu + ignition harness
Power Lock lt. green/red - in drivers door at switch
Power Unlock green/yellow - in drivers door at switch
Lock Motor brown/white in drivers door at switch
Unlock Motor brown in drivers door at switch
Parking Lights+ red/green steering column
Door Trigger red/white - low in drivers kick
Trunk/Hatch Pin purple/yellow - drivers kick or BCM
Hood Pin yellow/black - BCM
Trunk/Hatch Release purple/yellow - low drivers kick
Factory Alarm Arm arms w/ lock
Factory Alarm Disarm disarms w/ unlock
Tachometer white/green ac ECM
Brake Wire red/green + at brake switch
Horn Trigger green/white -
Keep in mind you have a 2nd start wire and 2 accessory wires. Unlock is double pulse.
Roger
Old Nov 23, 2003 | 08:05 PM
MaxZ71's Avatar
Installing an alarm on a car is not an easy thing to do it takes a good amount of electrical knowledge to do it. But if you are going to attemt it start out by find all the wiring in your car that you need to tap into. Also make sure you test the wiring dont just take someones word for it. To test it you need a voltmeter or something similar. After finding all the wiring in the car prep the alarm for the install. This includes figureing out which wires go where and twisting together any wiring that might go near the same section in the car. For example the siren output and the tach wire. when the alarm is finally preped all you have to do is wire it up. One other thing im not sure what year your maxima is but on the 2K2/3 it requires you to drill into a plug that leads into the doors to control the doorlocks. Be VERY VERY CAREFUL when doing this if you miss you could mess up that plug and loose the controls in the doors. It is fixable but im not sure how mich it would cost.
litch
123
Jan 4, 2024 07:01 PM
D Mason
Jun 21, 2016 04:43 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
bigfrank
Oct 1, 2015 12:51 PM
