Time for a new amp?
Old Nov 24, 2003 | 05:52 PM
OpTi's Avatar
Time for a new amp?
Hey. I got 2 1020w infinity reference subs. Peak is at 1000 and RMS is at 250. I'm currently using a profile (600sx i think) amp. I bought this used before because i was on a budget. I've saved up some money and if it's worth it i hope to upgrade to a 250 watts rms amp. The profile one is rated around 100 watts rms. Do you think that it'll be worth it to buy myself a new amp for christmas? If i do buy one, i'm gonna get one that's rated for around 200-250 watts RMS. Is it gonna be noticable different by pushing those subs with a new amp? I'm happy with my setup right now, it sounds decent but i wouldn't mind it hitting harder. Thanks for reading my long post!
Old Nov 24, 2003 | 06:04 PM
jmax
If you have two subs why not get an amp that can deliver 500 watts? That way you can use the full thermal limit of hte voice coil. The difference between 100 watts and 250 watts will be a little over 3 dB. The difference between 100 watts and 500 watts will be a little over 6 dB. Of course this leaves the box out of the equation.
Old Nov 24, 2003 | 06:27 PM
OpTi's Avatar
I'm not too familiar with ohms and such. Here's the link to the specs of the sub: http://infinityspeakers.com/caraudio/product.aspx?ProdId='1020W'&Ser=REF&Cat=SUB .
I did mean i was gonna get an amp that was about 250 watts x 2 channels. I'm not familiar with ohms but aren't most amps 250 x 2 at 2 ohms? It's also in a sealed box. Thanks
Old Nov 24, 2003 | 07:57 PM
jmax
Most of the sub amps are mono. You want a mono sub amp rated for 500 watts at 2 ohms. The subs you have are each 4 ohms nominal. Hook them up parallel for a two ohm load.
Old Nov 25, 2003 | 03:38 AM
LeX's Avatar
LeX
Nissan by Nature
If you're interested i am selling a Rockford Fosgate power500BD amp that is putting out 646RMS@2ohm.
Was running a single JL 12w6v2 and worked very nicely.
PM Me if you want
Old Nov 25, 2003 | 05:45 AM
jmax
That's a good amp for those subs.
6spd4dsc
May 9, 2022 12:30 PM
melteye
May 16, 2016 12:02 AM
2k11ApexEvo
Mar 30, 2016 06:54 PM
homeyclaus
Sep 3, 2015 06:15 PM
Abdelrhman
Aug 17, 2015 12:16 PM
