drilling into floor of trunk>?
Old Nov 29, 2003 | 05:45 PM
sk24iam's Avatar
Where can I drill into the floor of my trunk? Where can't I?
Old Nov 30, 2003 | 08:51 AM
erty67's Avatar
Decal Specialist
if you look under the trunk, near the fender, there is a drain plug. It's just a little rubber tube. Around there may be you best bet. I actually have a wire running through that tube. just an idea
Old Nov 30, 2003 | 09:09 AM
TAPOUT's Avatar
You will lose
As long as you use a grommet, and make sure you seal it up with silicone, you can drill almost anywhere in your trunk. Just look under the car near the spot that you want to drill to make sure you don't kit anything.
Old Nov 30, 2003 | 12:50 PM
sk24iam's Avatar
It's for my subs to be mounted. Where is the gas tank?
Old Nov 30, 2003 | 02:20 PM
ILOVEMYSE's Avatar
Just be careful. Had a hole drilled into my gas tank. Not pretty and not cheap.
Old Dec 1, 2003 | 09:18 PM
nismos14's Avatar
§è~® f®ÈÄk
in what general area is the gas tank?
Old Dec 2, 2003 | 09:03 AM
image's Avatar
be careful! dont drill into your gas tank. Wait i dont even think that is in the trunk... Its in the back seat.. for 4th gens... (gas tank= take out back seat.. undo all 30 of the 12mm bolts and your fuelline/tank area should be right there on the right... located on the side of your gas tank)
sliptap
Sep 30, 2015 05:57 AM
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
Socalstillen
Sep 26, 2015 12:01 PM
