Can I cut out the plastic door grills and...
Old Dec 3, 2003 | 10:30 PM
02MaXiMa_GLE's Avatar
If the components I ordered are too deep, is it possible to cut the plastic door panel (grill) and mount the speaker directly on the plastic door trim? I know it can be done, I'm just asking to see if it will generate waaaay too much vibration between the door trim, and the metal door. I plan on using a foam baffle from Crutchfield to "contain" the sound.
Has anyone done this on a 5th gen? Does is sound ok?...
Thanks,
G
Old Dec 3, 2003 | 10:32 PM
AscendantMax's Avatar
i think it's more of a support issue. would the plastic be able to support the speaker? some of those magnets can get heavy and over time the plastic might crack under the stress. my $.02
Old Dec 3, 2003 | 10:35 PM
SEmy2K2go's Avatar
Go BUCKS!!!
You shouldn't have any depth issues with your new component set fitting behind the door panel grille. I just installed a JL Audio component set and mounted the 6.5" woofers on 3/4" MDF mounting rings, and there is no issues at all. You should be just fine.
Old Dec 3, 2003 | 10:54 PM
Sweet! Where did you get those MDF rings?...
G
Old Dec 3, 2003 | 11:03 PM
SEmy2K2go's Avatar
Go BUCKS!!!
G
I made them. When you get your component set, most likely, you'll get a template with the diameter of the hole you would need to cut out when mounting the woofer into a location. What you do is, cut out the hole for the diameter of the new woofer in a sheet of MDF. Then take the factory speakers and center the magnet into the new 6" hole you just cut out. Trace an outline of the factory speaker which has 3 rounded areas in which the woofer screws to the door frame. Simply cut out the new ring, get some longer self-drilling metal screws from Lowe's or HD and you're golden. I'll post a pic of one of the ones I made for my install from over the weekend.
Old Dec 4, 2003 | 10:33 AM
nupe500's Avatar
Jedi Knight
G,
You better not do that , ....jeez...just give me a holla and we'll make it work..the right way!
O
Old Dec 4, 2003 | 11:11 AM
OUCH bro... Damn I got a SLAP and a KICK in the nuts.
Sounds good man... I'm sure we can tackle it no problem, O!...
G
Old Dec 4, 2003 | 11:38 AM
slickrick's Avatar
G
enjoy those cdt's. im not sure if im getting my system installed now. i went to circuit city and they asked ridiculas prices to install everyting. they wanted $120 for the steering whell controls part and 60 for labor. what a joke. you may need to dynamat your doors because those cdt's are so good.
Old Dec 4, 2003 | 12:28 PM
kgb006's Avatar
Thanks,
G
what component did you get?
Old Dec 4, 2003 | 05:43 PM
slickrick's Avatar
Thanks,
G
hey, how long does it take to ship the cdt's? im gonna install my system with a friend and i just may buy them.
Old Dec 4, 2003 | 05:47 PM
nupe500's Avatar
Jedi Knight
G
man...hit me up...u should still have my work info...if not PM me and I'll get you the math!
Old Dec 4, 2003 | 06:13 PM
Scheduled delivery is Friday the 5th. I may not get a chance to install this weekend due to weather... or I may just wait for my amp.
Ola, I'll hit you up when I get ready to drop 'em in... What do you mean by "the math" ?... I thought I always got better grades than you
-jk I still have your info, bro!
G
Old Dec 4, 2003 | 06:16 PM
The HD-62CF up front:
http://www.thezeb.com/caraudio/CDT_A...omponents.html
and CL-6X for the rear:
http://www.thezeb.com/caraudio/CDT_Audio_FullRange.html
Notice the 4 & 3 year warranties!
G
Old Dec 4, 2003 | 06:25 PM
slickrick's Avatar
G
are you running them off the h/u or an amp? i think im gonan buy them tomorrow because with free shipping they are actually cheaper than the kappas. i just hope they are not a pita to install myself.
Old Dec 4, 2003 | 06:43 PM
Haha sucka... I was kidding!
No really.. I bought them and they'll be here tomorrow. Are you also buying the rears? According to ABS you should be able to run them off the stock Bose amp up front. However, and amp is REALLY needed to drive these carbons (from what I hear)
I have the crappy Bose setup, so I may just wait and install with an aftermarket amp. Would you believe that the Sentra's NON-BOSE setup sounds WAAAAY BETTER than my Bose! Even the Bass is louder & cleaner!
G
Old Dec 4, 2003 | 07:28 PM
SEmy2K2go's Avatar
Go BUCKS!!!
02MaXiMa_GLE, here is a pic of the ring setup I was speaking of yesterday.
Hope that helps out some.
Old Dec 4, 2003 | 08:04 PM
sk24iam's Avatar
Would a jig saw work for this?
Old Dec 4, 2003 | 08:05 PM
sk24iam's Avatar
and would this also work? http://www.crutchfield.com/cgi-bin/S...o&i=003SG600DX
Old Dec 4, 2003 | 09:06 PM
slickrick's Avatar
G
how much are the rears? i just may have to do it before they sell out.
Old Dec 5, 2003 | 02:23 AM
$45 shipped...
G
Old Dec 5, 2003 | 02:24 AM
Looks amazing!
G
Old Dec 5, 2003 | 05:49 AM
nupe500's Avatar
Jedi Knight
G
Old Dec 5, 2003 | 06:37 AM
PoLo's Avatar
2-Wheelin it...
Looks amazing!
G
another example of an MDF cutout....
Diamond Audio Hex on 1" MDF Ring
Old Dec 5, 2003 | 10:54 AM
slickrick's Avatar
$45 shipped...
G
alright. i just ordered both the fronts and back online. just under $200. im excited.
Old Dec 5, 2003 | 11:00 AM
Huh?... I paid $200 + $45??? Did you get the CF ones? Which model# did you order? The CF ones come with silk-dome tweeter.
I just popped the box open. The Carbons look nice. The coaxials came in a small box... but I think I'll keep them. Some people say they work great. If need be I can always replace in the future Besides they're the only coaxials that CDT makes (except for the Braxials)
Now I need Foam baffles from Crutchfield for all 4 speakers & the 8" deck sub!
G
Old Dec 5, 2003 | 11:40 AM
slickrick's Avatar
G
nah. i got the ones for 149 with the bad paint. and i got the cl6x 6.5 coaxials. why doe we need baffles? because they wont fit?
Old Dec 5, 2003 | 02:06 PM
sk24iam's Avatar
Is it better to take out the stock baffles? I kept mine in and added a ring adaptor on top of that. Maybe that's why I had fitment issues.
Old Dec 6, 2003 | 10:22 AM
sk24iam's Avatar
Would 1/2 inch mdf work or would it hit th window?
Old Dec 6, 2003 | 04:22 PM
nah. why doe we need baffles? because they wont fit?
To protect the speakers from outside moisture & it also helps with the acoustics.
G
Old Dec 6, 2003 | 05:42 PM
slickrick's Avatar
G
do these really work and is it necessary?
Old Dec 7, 2003 | 02:17 AM
TAPOUT's Avatar
You will lose
Just a quick word to the wise, if you put MDF in the door, you had better coat it with something. MDF does not mix with water. It will expand to over double its thickness. I have been installing for 12 years, and I have taken out some nasty stuff from people not putting a little fiberglass resin on the MDF. I have seen it warp the speaker frame over 1/2 an inch. I would actually recommend using plywood over MDF in the door if you cannot fiberglass the MDF
bigdogsteve
Jan 31, 2018 04:18 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
ricky7780
Sep 24, 2015 06:50 PM
lrb6805
Sep 24, 2015 05:03 PM
