Clean Stereo Installs
Old Feb 26, 2001 | 10:36 AM
felix_xiii's Avatar
I have a question about the clean custom installs you see on all the show cars. To make everything blend with your trunk like sweetsounds did, what do you use? Is that MDF or plywood or what? Also does that weigh a lot? I am very concious about weight. Thanks.
Old Feb 26, 2001 | 11:59 AM
Whitemax's Avatar
Disco Biscuit
Well, usually it's a combo of MDF, HDF(if you can find High density), fiberglass, bondo, viyl, carpet, etc. But yes, the base for most installs is MDF. As far as weight goes, yes it can add trmendous amounts of weight depending on the size and complexity of the enclosures and trims.
Old Feb 26, 2001 | 05:35 PM
Botos's Avatar
MDF will weigh you down; if you want some lighter alternatives, look into fiberglass or - if you're really fanatical about weight and have the budget - carbon fiber.
Old Feb 26, 2001 | 06:38 PM
SWEETSOUND2001's Avatar
my car is slowwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww
muahahahah
Old Feb 26, 2001 | 09:05 PM
Matt93SE's Avatar
STFU n00b!
Yup.. weight skyrockets when you start doing stuff in the trunk.. with all the equipment in there, my system weighs about 280-320lb.
the sub box weighs almost 100lb, and the amp rack weighs 80lb.... that's just wood, carpet, and plexiglass.
Add another 60lb for subs, 30lb of amps, and 20lb of wire (probably more. 2awg wire is HEAVY!!)
Drawbacks: slow acceleration.
benefits: the *** end sticks like glue in corners.
With only the system and sway bars, I could outhandle another 3rd gen with full suspension mods.
I'm planning on dumping the whole trunk soon though. I'll keep the amps, but I'm going to lose the subs, sealed box, and amprack.
it's gonna be purdy..
let's just say 4 12" subs, carbon fiber, kevlar, polished stainless steel, and aluminum.
Matt93SE
May 24, 2019 02:58 PM
trasmadean
Feb 1, 2017 08:20 PM
melteye
May 16, 2016 12:02 AM
DayHeyZeus
Garage and Workshop
Aug 16, 2015 12:29 AM
MikesChevelle
Aug 6, 2015 11:36 AM
